time dependent velocity input by user subroutine
Old   December 17, 2007, 16:16
Default time dependent velocity input by user subroutine
shohel mahmud
Hi Everybody I am struggling with a simple transient model. I have a 2-D rectangular channel with one inlet, one outlet, and two walls. At the inlet, V and W velocity are zero. Only U velocity is time dependent. For example, U=U0*sin(2*pi*f*time) where, U0, f, and time are velocity amplitude, frequency, and time or iteration number. How can I set this boundary condition in starcd user subroutine? The existing subrutine only accept spatial variation not temporal.
any help will be greatly appreciated
shohel
university of waterloo
Old   December 17, 2007, 16:56
Default Re: time dependent velocity input by user subrouti
Pauli
The user subroutine bcdefi.f supports time dependant velocity boundary conditions.
Another option is to use a table.
Old   December 17, 2007, 19:56
shohel mahmud
Thanks Pauli I don't know how to implement time in the bcdefi.f suroutine. Specially, no idea about variable time or time step. Below I copied a portion of the bcdefi.f subroutine and show an example of time variation of U. lots of question mark, I don't know what to put to consider the time or time step or iteration. Do I need to "include" any new inc file or add new EQUIVALENCE. Your help will be greatly appreciated.
IF(IREG.EQ.2) THEN
TURINT=.FALSE.
U=2.3*sin(2*22/7*??????)
V=0.0
W=0.0
TE=0.0
ED=0.0
T=0
V22=0.0
F22=0.0
SCALAR(1)=0.0
DEN=0
ENDIF
RETURN
END C
Old   December 18, 2007, 07:50
James
If you look in nom.inc the variable time should be available (it comes through a common block not the call list)
Old   December 18, 2007, 11:40
Pauli
The bcdefi.f template should include the line:
INCLUDE 'usrdat.inc'
This gives you access to a parameter "TIME". So for your example:
U=2.3*sin(2*22/7*TIME)
When you tell Star to write the usubs, it should put usrdat.inc into the ufile subdirectory.
On my system I have to create the ufile subdirectory manually. Otherwise when I try to write the usubs, Star reports the directory doesn't exist.
time dependent inlet subroutine. HELP!!! jimmer Siemens 4 November 10, 2008 08:49
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 01:22
user subroutine BCDEFW for velocity Abe Siemens 2 December 12, 2003 09:29
CFX5.5 User Subroutine defining velocity B.C. David CFX 7 March 4, 2003 19:02
Modification in a Time Dependent Velocity Guillermo Solano Phoenics 4 April 8, 2002 03:34
