Home > Forums > CD-adapco
v4 & AMG warning msg
Like Tree3Likes
  • 2 Post By rcm
  • 1 Post By rcm
Old   December 19, 2007, 05:56
Default v4 & AMG warning msg
more work
Hi! I'm now running v4 but using trim mesh created in v3. It ran quite well earlier without porous media. However, now in a model containing porous media I got this warning msg below but only after 45 iterations onwards. Kindly someone let me what this warning message means.
45 2.75E-01 1.00E+00 7.00E-01 -- -- -- -- 1.03E+05-6.73E+13 4.40E-01 -- -- -- -- FINISH ITERATION NO. 45 CPU time is 306.86 Elapsed time is 307.11
46 3.82E-01 1.00E+00 2.81E-01 -- -- -- -- 3.04E+05-1.05E+14 6.09E-01 -- -- -- -- FINISH ITERATION NO. 46 CPU time is 311.89 Elapsed time is 312.14 WARNING: Ap = 0 on multigrid level 1, nRows = 49184, blockSize = 1
AMG coarsening halted. WARNING: Ap = 0 on multigrid level 1, nRows = 49974, blockSize = 1
AMG coarsening halted. WARNING: Ap = 0 on multigrid level 1, nRows = 50823, blockSize = 1
47 2.92E-01 1.00E+00 6.90E-01 -- -- -- -- 2.73E+05-1.06E+14 1.67E+00 -- -- -- -- FINISH ITERATION NO. 47 CPU time is 400.92 Elapsed time is 401.17 WARNING: Ap = 0 on multigrid level 1, nRows = 49011, blockSize = 1
AMG coarsening halted. WARNING: Ap = 0 on multigrid level 1, nRows = 50353, blockSize = 1
AMG coarsening halted. WARNING: Ap = 0 on multigrid level 1, nRows = 49831, blockSize = 1
Old   March 7, 2012, 00:34
rcm
chetan
rcm is on a distinguished road
This is due to small un conected surfaces in mesh
To rectify this right click and select repair surface in Representation >> remeshed surface, which you can find below plots
A new window called Surface Prepration Options will pop up. Click OK
In the side pane, select mode as "Edit conected surfaces" from the drop down and click start diagonosis
it will display more than one line of surface groups in a table.
Highlight and delete the small unconnected surfaces and close the window.
Select generate volume mesh to remesh
Jimmy123 and fshak92 like this.
rcm is offline   Reply With Quote
Old   March 28, 2012, 08:42
fshak92 is on a distinguished road
Do we have to regenerate a volume mesh after using 'remove invalid cells in region' ? or it is compulsory just after using surface repair?
Thank you in advance.
fshak92 is offline   Reply With Quote
Old   March 28, 2012, 09:56
rcm
chetan
yes. generate volume mesh and switch on cell quality remediation
fshak92 likes this.
Old   March 29, 2012, 04:47
Thank you for your answer.
Just a question.After removing some cells by 'remove invalid cells' ,first i did not regenerate volume mesh.So we should expect the residual isn't changed.
but it was changed a lot.
What does it mean?
Thread Tools
Trackbacks are On
Warning 046, what does it mean? SAKTI CD-adapco 1 July 31, 2008 12:14
warning #064 ema CD-adapco 1 August 25, 2005 05:45
warning # 90 vishal CD-adapco 1 August 11, 2005 09:19
*** WARNING #052 *** Cirilo CD-adapco 1 July 27, 2005 08:34
Warning Paco CD-adapco 0 June 23, 2005 02:33
