Error in compressible flow
Old   December 26, 2007, 23:19
Default Error in compressible flow
krish
Hi all,
I am doing compressible flow(air) analysis.
Inlet boundary condition = velocity = 39 m/s( constant mass flux) Outlet pressure boundary = 1 bar.
After some time i am getting this error
*** WARNING #060 *** DENSITY OUT OF BOUND DUE TO PRESSURE CORRECTION AT CELL 1 DENSITY= -1.8867E+00 LIMITER APPLIED
Finally it says
"Negative densities found at more than 100 cells" RUN STOPPED.
Please give me some suggestions to sort this problem.
Regards Krish
Old   December 27, 2007, 08:43
Default Re: Error in compressible flow
Balduin Bankerotti
1) search in the forum for "Negative densities found at more than 100 cells"
2) reduce the unterrelaxation for density
highly compressible flow : Fluent Error Message Amit Shrestha FLUENT 5 December 19, 2018 07:43
Internal Flow BCs for Compressible inlet flow Katie FLUENT 2 March 3, 2012 17:35
Internal error in compressible flow be density Mirek FLUENT 0 August 20, 2008 08:59
Mass flow inlet compressible flow richard FLUENT 2 June 1, 2008 11:44
External Flow-compressible flow solver-lift/drag Tom Brown Main CFD Forum 7 December 29, 2000 13:41
