Home > Forums > CD-adapco
star-ccm+ problem, what's wrong with it!
Old   January 8, 2008, 09:53
Default star-ccm+ problem, what's wrong with it!
june
I installed star-ccm+ 2.08 on 64bit linux machine with opensuse 10.3, and when I create new sim file, ccm+ shows this exception error message and stopped, and it shows same error message when open the sim file too. I used to install version 2.08.007 ccm+ and have a legal license. Does anyone experienced same? if you know the solution. please hlep me! +++++++++++++++++++++++++++++++++++++++++++++++++ exception java.io.IOException: java.io.IOException: /usr/ccm/starccm+2.08.007/star/local/bin/bash: not found. +++++++++++++++++++++++++++++++++++++++++++++++++
show details ++++++++++++++++++++++++++++++++++++++ Annotation: java.io.IOException: java.io.IOException: /usr/ccm/starccm+2.08.007/star/local/bin/bash: not found. java.io.IOException: java.io.IOException: /usr/ccm/starccm+2.08.007/star/local/bin/bash: not found.
at star.base.neo.ServerConnection.startLocal(ServerCo nnection.java:367)
at star.base.neo.ServerConnection.startServer(ServerC onnection.java:319)
at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:108)
at star.base.neo.ServerConnection.<init>(ServerConnec tion.java:93)
at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:183)
at star.coremodule.SimulationProcessObject.<init>(Sim ulationProcessObject.java:170)
at star.coremodule.ui.OpenOptionsDialog$1.run(OpenOpt ionsDialog.java:83)
at org.openide.util.RequestProcessor$Task.run(Request Processor.java:499) [catch] at org.openide.util.RequestProcessor$Processor.run(Re questProcessor.java:932) Caused by: java.io.IOException: java.io.IOException: /usr/ccm/starccm+2.08.007/star/local/bin/bash: not found
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java :451)
at java.lang.Runtime.exec(Runtime.java:591)
at java.lang.Runtime.exec(Runtime.java:464)
at star.base.neo.ServerConnection.startLocal(ServerCo nnection.java:363)
... 8 more
Old   January 8, 2008, 19:52
Default Re: star-ccm+ problem, what's wrong with it!
try this
may be try another shell. Bash shell are usually the worse ones. May be run in csh or tcsh.
Old   January 8, 2008, 21:25
june
thanks. your response solved my problem. thanks a lot!
Thread Tools
Trackbacks are On
DPM problem - wrong particle temperature Johannes FLUENT 1 December 1, 2014 13:48
What's wrong? Non-conform mesh problem!!! Neo FLUENT 1 March 31, 2013 15:00
the problem of running star-cd after pro-star liu-jinsong CD-adapco 0 November 20, 2008 21:58
Library problem on a 64bit machine wrong ELF class ELFCLASS32 jango OpenFOAM Installation 0 June 11, 2007 07:29
Problem with LaunderSharma compressible turbulence model wrong formulation luca OpenFOAM Running, Solving & CFD 4 July 3, 2006 06:24
