atomization model vs breakup model
Old   December 20, 2007, 02:35
Default atomization model vs breakup model
Jay
Can anybody explain to me the difference btn atomization model and breakup model?
Old   December 20, 2007, 04:39
Default Re: atomization model vs breakup model
dong
atomization model - primary breakup, i.e. the breakup of the liquid as it leaves the nozzle
breakup model - secondary breakup, i.e. the further breakup of the droplets due to interaction with the flow field.
Old   December 20, 2007, 11:35
Jay
I mean both model in Star-CD. there are several models of both case in star-cd
So, you mean I can't deal with primary breakup thru breakup model such as Hsiang and Faeth model.
Is that right?
Old   December 20, 2007, 16:30
Pauli
No.
Details regarding the droplet breakup and spray atomization models are described in section 12 of the version 3.26 methodology manual.
If you don't like what's built into the code, you might be able to code you own algorithms via user subroutines. I've never tried this so I'm not sure exactly how far you can go.
Old   December 21, 2007, 00:50
Jay
Actually I have Star-cd ver.3.24
Pauli, would u like to send the ver.3.26 methodology?
Old   December 21, 2007, 19:32
Pauli
Sorry but tha's copyrighted material.
You should have a copy in your installation. If not, it's on the installation disks. It's a PDF file. It should be installed at:
$STARDIR/PROSTAR/3.26.008/man/method/star_method.pdf
You will need to replace 3.26.008 with your version.
Old   January 24, 2008, 19:41
Andrea
Hi Jay,
you can find detailed description of model also on literature...and also in old metodology books from Cd-Adapco! I use ver 3.26 too and I have that met. but a detailed and sufficient description of breakup/atomization models it's also present on metodology ver 3.22...hope it's tha same for ver 3.24!
There aren't any big changes in those models...
Regards,
Andrea
Old   January 24, 2008, 19:51
Andrea
Well, if you're interested in a model that predict the atomization process and also the secondary breakup, just try to use the Reitz-Diwakar models for those subjects. It's a model that can be extended from atomization to secondary breakup...so you don't need to modify many constants...
Hope that helps you...
Regards
Another breakup model Jay, Choi Siemens 5 January 13, 2010 13:36
flat-fan atomization model --------DPM bohis FLUENT 0 April 30, 2008 05:42
the role of the atomization model Jay Siemens 2 March 7, 2008 20:16
help to build an atomization model Please Mido FLUENT 1 March 1, 2008 08:39
Urgent please, help with an atomization model mido Main CFD Forum 0 February 24, 2008 12:31
