Define time step
Old   January 31, 2008, 15:02
Default Define time step
Pepe
I'd like to increase the time step in my transient simulation. But when I do that the calculation becomes unstable and diverge although it's an implicit calculation (thought in that case the Courant-number is not the crucial part).
Is there anyway to increase the time step?
Thanks!
Old   February 1, 2008, 10:49
Default Re: Define time step
murash-v
If you are use mars schem you can encrease blending factor for example up to 0.9. Another method is use switch/real constants parametres, but such numbers are usually unknown, so you must wright email for autors. Also for this method autors not garant validate data.
Old   February 1, 2008, 12:39
James
PISO typically works 'fastest' at around 4 corrector stages per time step, if you get the longest time step that does 4 PISO stages (typically with max Courant ~100) you will get about the best CPU time versus simulation time that you can.
Old   February 3, 2008, 11:26
Pauli
1) Increase your mesh size. In particular, increase the size of small cells in high velocity regions.
2) Run UD discretization.
3) Watch for non-physical results. In other words, this may let your simulation run faster (larger step size) but might not give you a usable answer.
Time step size and max iterations per time step pUl| FLUENT 33 October 23, 2020 22:50
SELECTING TIME STEP SIZE, NUMBER OF TIME STEP NITUL KALITA FLUENT 2 November 22, 2012 08:28
Long time CHT transient simulation time step.... JP CFX 0 May 9, 2008 03:36
define moving mesh for engine step by step homan FLUENT 0 October 26, 2005 03:27
Relation of computational time step with real time Salman Main CFD Forum 2 August 3, 2005 14:13
