Home > Forums > CD-adapco
Warning 020
Old   February 11, 2008, 09:10
Default Warning 020
Pepe
Hello, I got the following error message (although the simulation works fine).
*** WARNING #020 *** CELL CENTRE OUTSIDE OF THE CELL FOR CELL NO. 41642
How does this affect my solution or the speed of the run? And how can I fix it?
Thank you!
Pepe
Old   February 11, 2008, 17:45
Default Re: Warning 020
Kyle
That is a concave cell. It's center of mass does not lie within the cell itself. I wouldn't worry too much about it unless you have several of them.
Old   February 11, 2008, 18:00
Polder
You should worry about them, it means the fluxes at this location will be applied somewhere else than this location, and most likely mess up your solution. Imagine a volume so distorted the center is outside the cell.
It is usually called "Elephantman mesh"
good luck
Polder
Old   February 12, 2008, 04:42
Mangesh
Check the centroid and concave element. If centroid, then it will affect the solution.
Old   February 12, 2008, 13:37
Pepe
Well, it's pretty strange. I got this error message with plenty of cells (let's say hundreds), but they all look fine. No immoderate distortion or streching.
Cannot find the source of it..
Thread Tools
Trackbacks are On
Warning 046, what does it mean? SAKTI CD-adapco 1 July 31, 2008 12:14
warning #064 ema CD-adapco 1 August 25, 2005 05:45
warning # 90 vishal CD-adapco 1 August 11, 2005 09:19
*** WARNING #052 *** Cirilo CD-adapco 1 July 27, 2005 08:34
Warning Paco CD-adapco 0 June 23, 2005 02:33
