February 26, 2008, 20:38 |
Turbulence Model
hi, every1 i am using star-design to do my final year project ,i was ask to very the turbulence model which are ke model and constant viscosity model. however in the option i can only find ke model on/off, how do i use constant effective viscosity model then ? ( is it just turn the ke off and density to constant >? )
February 27, 2008, 19:09 |
Re: Turbulence Model
what do you mean for costant viscosity models? I don't understand...you're speaking about turbulence model but you want a model where you consider a costant viscosity for your liquid? If I'm not wrong every turbulence model consider a variable viscosity in the liquid...it's implicit in the turbulence phenomena...then you can choose to use a scala relationship between viscosity and shear stress or not...but that's another question... Plase be more specific Regards |
February 28, 2008, 10:16 |
Star Design is a very pared down CFD program. You can chose either k-epsilon turbulence model or laminar flow. Star-CD offers a much wider range of tubulence models. Constant viscosity is the most simple one. So if you are to compare those two models you should use Star-CD.
March 3, 2008, 20:06 |
Sorry for my previous message, now I understand...
Display Modes | |
changing model constants in k-e turbulence model | Sunil | CFX | 3 | October 3, 2006 13:12 |
turbulence model | greg | FLUENT | 3 | August 26, 2006 12:07 |
v2-f model of turbulence | abdellah | FLUENT | 2 | February 27, 2005 01:49 |
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? | Mirek Kabacinski | FLUENT | 5 | August 24, 2003 23:31 |
k-w turbulence model | allan | Main CFD Forum | 4 | February 20, 2002 14:05 |
