-   Siemens (https://www.cfd-online.com/Forums/siemens/)
-   -   error in cyclic boundaries match (https://www.cfd-online.com/Forums/siemens/56479-error-cyclic-boundaries-match.html)
Steve February 29, 2008 09:51
I have problem in making the match of cyclic boundaries.If i select only one cell of a cyclic boundary with the corresponding cell of the other cyclic boundary it makes me the match, but for more than one cells, the next error appears "the following multiple boundaries all share identical locations and will not be mached", any propose what the error about is?
James February 29, 2008 14:54
Re: error in cyclic boundaries match
Your matching tolerance would appear to be too large in CYMATCH or CYARBIT.
Is the model in meters with very small cells? One possible fix is to move it to mm alternatively change the tolerance on the match command.
Steve March 4, 2008 04:32
my problem is in mm, unfortunately it doesnt seem to be a tolerance problem
