the role of the atomization model
Old   March 6, 2008, 09:28
Default the role of the atomization model
Jay
Hi
I try to model spray injection.
In Star-cd, there are 4 atomization models.
According to the methodology, nozzle turbulence, surface wave growth, droplet size distribution, spray andgle and initial velocity will be calculated in atomization model.
I think this is very similar to the mechanism of the primary breakup.
And Star-cd also provide the droplet breakup model which I think the secondary breakup.
So, I want to analyze the spray injection model using primary and secondary breakup.
Is it possible? (primary breakup = atomization model) (secondary breakup = droplet breakup model)
Thanks and Regard...
Old   March 6, 2008, 09:34
Default Re: the role of the atomization model
usker
Yes, you are right.
Old   March 7, 2008, 20:16
Andrea
You are right:
atomization = primary breakup
breakup = secondary br.
I suggest to use Huh's model for the atomization (because with that model you don't have to specify any spray angle, so you'll get a "natural" spray angle, not forced numerically) and then to use Reitz or Hsiang-Faeth secondary breakup...
Sometimes at partial load you can get better results on the atomization by using Reitz-Model, but you need to know an exact spray angle...(and so you need experimental data)
atomization thomas FLUENT 5 October 25, 2010 10:16
flat-fan atomization model --------DPM bohis FLUENT 0 April 30, 2008 05:42
help to build an atomization model Please Mido FLUENT 1 March 1, 2008 08:39
Urgent please, help with an atomization model mido Main CFD Forum 0 February 24, 2008 12:31
atomization model vs breakup model Jay Siemens 7 January 24, 2008 19:51
