Home > Forums > CD-adapco
Ignition timing for diesel combustion
Old   March 8, 2008, 02:37
Default Ignition timing for diesel combustion
Ankur
Is it necessary to specify ignition timing for diesel combustion simulation.
Old   March 8, 2008, 07:29
Default Re: Ignition timing for diesel combustion
usker
Please elaborate, what exactly do you mean?
Old   March 8, 2008, 11:13
Pauli
No. You specify injection timing.
Old   March 9, 2008, 21:26
Andrea
Copy, you specify injection timing and second you can "influence" the injection timing...but it depends on the combustion model that you use:
- if you use a model associated with the Shell ingnition model you specify some ignition characteristic such as characteristic temperature, cetane number, etc.
- if you use comb. model from the ECFM family you can define only the cetane number and by means of that you can vary the time of combustion
Old   March 10, 2008, 00:44
Ankur
I am using shell auto ignition model and default value used is 1100K.Is it correct?
Old   March 15, 2008, 21:18
Andrea
Yes it is correct, you can try to vary the start of injection by means of the costant AF04 of the model. Try to vary it (by means of posdat.f for example)...a value of 2.5e6 may be a good fist attempt to match the correct ignition time
Thread Tools
Trackbacks are On
DIESEL COMBUSTION Benzamia FLUENT 8 January 22, 2012 01:33
Qs on combustion/ignition in CFX 5.5.1 beginner1 CFX 6 August 6, 2010 11:16
Ignition and combustion Mai CD-adapco 7 May 10, 2006 09:59
Heat Release and Ignition Timing in KIVA Felix Tae Main CFD Forum 0 January 25, 2006 02:08
diesel combustion zahir FLUENT 2 October 11, 2002 05:48
