Proam: Assembly
Old   March 5, 2008, 08:56
Default Proam: Assembly
Bala
Hello all,
While assembling the trimmed mesh with the extrusion (for an external flow mesh) so many sharp cells are protruding inside the inner domain. How to rectify this problem. Which causes this to protrude from all the directions? Can any one help me in this regard?
Old   March 15, 2008, 21:21
Default Re: Proam: Assembly
Andrea
have you checked out the initial surface before the extrusion process? May be that sharp cell are also present in the first surface saved before the extrusion process...you use the "auto" method to cover your core mesh with shells maybe you'll get some "extra" shell inside your model that you don't really want to have...
meshing assembly in gambit corey FLUENT 19 May 30, 2009 07:40
CFX-Block or Assembly? Susan CFX 0 November 20, 2007 06:23
creation of 3d bodies within an assembly Roland CFX 1 August 8, 2006 12:49
Grid Assembly Mir Siemens 5 April 24, 2002 07:59
assembly coding for CFD Andrei Chernousov Main CFD Forum 4 November 9, 2000 10:33
