Home > Forums > CD-adapco
Turning off .run & .info files
Old   March 14, 2008, 11:29
Default Turning off .run & .info files
Anton Lyaskin
Just curious - is there any way to turn off writing .run and .info files? Or to forward the output from these files to /dev/null?
I've just noticed that for small models and fast CPU time neccessary to update the output files is comparable to the time of iteration! Well, may be something is wrong with my disk system, but...
Old   March 17, 2008, 23:07
Default Re: Turning off .run & .info files
Pauli
I've never heard of a way. If you redirect the output to /dev/null you probably won't get a pst file.
You could ask the support folks if they have a magic switch or rcon.
Are you writing to a networked or local disk drive?
Old   March 18, 2008, 05:52
Anton Lyaskin
Yes, if I'll forward all the output to /dev/null, I'll loose everything.
I'm writing to a local disk, with network disk this the situation will be even worse! This prevents me from running a number of small problems in parallel on a cluster with network storage.
May be you're right about switches and rconstants, I'll try to find out
Old   March 18, 2008, 07:48
Balduin Bankerotti
There is nothing about this in the switch list.
Thread Tools
Trackbacks are On
turning ouputs into inputs (urgent) yosr FLUENT 4 December 19, 2008 06:34
Converting ANSYS CFX files to Fluent files Martin S. Rasmussen FLUENT 3 January 30, 2007 16:08
Hidden info in cas and dat files Dan FLUENT 0 June 7, 2006 07:40
turning off error messages and resetting flow time Phil FLUENT 1 November 24, 2003 10:35
info olivier Main CFD Forum 0 November 16, 2001 13:08
