Range of Y+ for two-layer approach in CCM+
Old   March 19, 2008, 00:40
Default Range of Y+ for two-layer approach in CCM+
VG
Hi What should be the control range for y+ when using realizable k-epsilon turbulence model with two-layer all y+ approach. I have a mesh in which y+ is varying from 0.001 to 50 while using above mentioned model.Can this model accomodate this range of y+ as its name suggesses (all y+) or y+ must be controlled below 1 like in Low-Reynolds number approach. Thanks in Advance.
Old   March 25, 2008, 14:29
Default Re: Range of Y+ for two-layer approach in CCM+
Achim Frahm
What is your aim? Correct pressure loss or heat transfer?
Theoreticaly y+ should not be in a range between 10-25.
To check it I would compare the results of two different calculations. One with a finer (y+=0.1-3) and one with a coarser mesh (y+=30-50). When the differences in results are small enough when it is ok.
Another possibility: make the mesh finer in areas with y+>5 with volume sources.
Achim
NRBC: Sponge layer approach jinwon park Main CFD Forum 1 December 5, 2013 07:33
y+ range Adam Stuchlik CFX 3 March 12, 2009 16:20
Face ID out of range Wenbin FLUENT 1 January 16, 2006 09:33
Global Range Stephen FLUENT 0 March 29, 2004 09:36
salary range Frank Muldoon Main CFD Forum 7 August 3, 1998 19:04
