Home > Forums > CD-adapco
CCM+ strange interface idea?
Old   March 24, 2008, 17:07
Default CCM+ strange interface idea?
Peter Specht
When you importe two regions which have an area where they fit together you have to create an interface in-place so that the flow can go through the two areas of the two regions. Why can not create CCM+ these interfaces on its own? It is a stupid work in complicated models to create dozen of interfaces e.g. models with many porosities!
Regards Peter
Old   March 25, 2008, 07:44
Default Re: CCM+ strange interface idea?
steve
Hi Peter
STAR-CCM+ has a functionality called split by surface topology. Have a look in the help for more information.
I use it all time for complex geometries. Does this do what you want?
Steve
Old   March 29, 2008, 07:59
Peter Specht
No. When you have two regions that share one boundary you can not use this function. You have to look for the two areas that lay on each other, mark them and then create interface in place. It is a pity that this do not work automatically.
Peter
Old   April 3, 2008, 07:50
Timmy
If you merge the two regions together, then do a split by surface topology it will automatically create the two regions and the interfaces between them.
Thread Tools
Trackbacks are On
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 13:04
Is this idea new or old zou_mo OpenFOAM Meshing Format & General Technical 1 May 22, 2006 00:38
what is your idea? REZA FLUENT 1 March 8, 2006 01:05
please your help if u have idea elzubier FLUENT 3 December 18, 2005 10:44
LES idea B. Saunders. Main CFD Forum 5 February 25, 2002 13:56
