Home > Forums > CD-adapco
Compilation Error when running Tutorial 2.4
Old   March 28, 2008, 14:10
Default Compilation Error when running Tutorial 2.4
zhihuali
Hi all,
I tried tutorial 2.4 and the following error appeared when I started the calculation:
PNP: Initialized [2008-03-28-18:42:30] Automatic Sequential Automatic Parallel analyzer.
PNP: Allocated "lizhihua,1" resource (1 process).
PNP: Assigned "lizhihua,1" to STAR solver (1 process).
PNP: Analyzing User coding in "ufile" directory.
PNP: compiling /opt/absoft/bin/f90 -w -fPIC -YCCM_NAMES=LCS -YEXT_NAMES=LCS -YEXT_SFX=_-B19 -cpupteron -mcmodel=medium -m64 -c droico.f -o linux64_2.4-absoft_9.0a-glibc_2.2.5-dso/dp/droico.o
PNP:
PNP:Error: bad option: -cpupteron
PNP: ***ERROR*** Compilation error in user file "ufile/droico.f".
PNP: ==> Please check the compilation error messages.
The fortran package I installed is profortran75
My linux is a 64 bit rehat enterprise 4
Starcd version:3.24 with x86_64 platform
I checked the messages in this forum that menstion similar problems, to which answer is their fortran is too old.But the error I have is not the all the same, and I dont know how to solve it.
Does anybody know why this occurs?Any resolution?
Many thanks in advance!
Zhihua
Old   March 28, 2008, 14:49
Default Re: Compilation Error when running Tutorial 2.4
James
You have to use the fortran package specified in the install notes which for 3.24 is ABSOFT, you can't use any other fortran compiler.
Old   March 28, 2008, 16:28
Pauli
It seems like I've run into this problem. Unfortunately I don't remember the answer.
It looks like they are using ABSOFT ( PNP: compiling /opt/absoft/bin/f90 ...). The problem is that the compiler is bing fed an invalid option (PNP:Error: bad option: -cpupteron).
Is it a setting in software.ini or hardware.ini? I don't have a 3.24 installation. I checked my 3.26 installation but didn't spot anything which looked appropriate.
Old   March 28, 2008, 16:39
James
see my previous answer....(although in 3.26 you can use PGI too)
Old   March 29, 2008, 15:54
zhihuali
Thanks for your answer.
I found my software.ini file in starcd/etc, and in the linux settings, there seems to be 2 linux platforms(x86 and x86_64)installed and different versions of aboft are involved for the 2 platforms. Does this cause the error?
(When I installed starcd 3.24, there are two options,x86 and x86_64, in the Platforms Section, and I chose the latter. I dont know why there appears to be two platforms.)
Linux settings in my Software.ini:
# Linux settings
platform Linux_x86 FLEXLM=$FLEXLMTOP/linux_2.4-x86-glibc_2.2.2
platform Linux_x86 LAMHOME=$LAMTOP/linux_2.4-gcc_2.95.3-glibc_2.2.2-dso
platform Linux_x86 MPICH=$MPICHTOP/linux_2.4-gcc_2.95.3-glibc_2.2.2-dso
platform Linux_x86 PROSTAR=$PROSTARTOP/linux_2.2-x86-glibc_2.2.0
group Linux_x86-glibc_2.3.2 PROSTAR=$PROSTARTOP/linux_2.4-x86-glibc_2.3.2
platform Linux_x86 RUNTIME=$RUNTIMETOP/linux_2.4-x86-glibc_2.2.2
platform Linux_x86 STAR=$STARTOP/linux_2.4-absoft_8.2ap1-glibc_2.2.2-dso
##platform Linux_x86 STAR=$STARTOP/linux_2.4-ifc_7.0-glibc_2.2.2-dso
platform Linux_x86 STARLAUNCH=$STARLAUNCHTOP/linux_2.2-x86-glibc_2.2.0
platform Linux_x86_64 FLEXLM=$FLEXLMTOP/linux64_2.4-x86-glibc_2.2.5
platform Linux_x86_64 LAMHOME=$LAMTOP/linux64_2.4-gcc_3.2.2-glibc_2.2.5-dso
platform Linux_x86_64 MPICH=$MPICHTOP/linux64_2.4-gcc_3.2.2-glibc_2.2.5-dso
platform Linux_x86_64 PROSTAR=$PROSTARTOP/linux64_2.4-x86-glibc_2.2.5
platform Linux_x86_64 RUNTIME=$RUNTIMETOP/linux64_2.4-x86-glibc_2.2.5
platform Linux_x86_64 STAR=$STARTOP/linux64_2.4-absoft_9.0a-glibc_2.2.5-dso
##platform Linux_x86_64 STAR=$STARTOP/linux64_2.4-pgf90_5.2-glibc_2.2.5-dso
platform Linux_x86_64 STARLAUNCH=$STARLAUNCHTOP/linux64_2.4-x86-glibc_2.2.5
Zhihua Li
Old   March 30, 2008, 05:50
James
Unless you have absoft installed you are not going to get anywhere, it doesn't matter which port of the code you use, you still have to have the absoft compiler to use subroutines. Absoft isn't included in the installation you have to purchase/install it separately
Old   March 30, 2008, 09:55
zhihuali
Thanks!
I did install, separately, absoft to the /opt directory, but now I found it is a 32 bit absoft that probably caused the problem?
Zhihua Li
Old   April 1, 2008, 07:34
zhihuali
Hi there,
I borrowed pgi6.0 and installed it. However, after the display of model specifications, another error appeared:
/usr/starcd/STAR/3.24.000/linux64_2.4-pgf90_5.2glibc_2.2.5-dso/lib/star: symbol lookup error: /home/lzh/1/ufile/linux64_2.4-pgf90_5.2glibc_2.2.5-dso/dp/libstarusr.so: undefined symbol:__fmth_i_dlog PNP:Shut down [2008-04-01-11:52:11]Execution aborted by request (SIGABRT) after 1 seconds(TOTAL ELAPSED TIME)
What does that mean?
Zhihua
Thread Tools
Trackbacks are On
Problem in running tutorial cases preetham OpenFOAM Installation 2 June 13, 2009 16:36
udf compilation error sdp FLUENT 0 February 5, 2009 03:58
UDF compilation error Hari FLUENT 0 February 22, 2008 14:40
Running Tutorial Eulerian Granular Heat file Femi FLUENT 0 March 8, 2007 13:01
Tutorial is not running on star-CD version 3.2 Arnab CD-adapco 0 August 30, 2004 15:43
