Home > Forums > CD-adapco
Problem with starcd in parallel
Old   April 9, 2008, 13:52
Default Problem with starcd in parallel
Alessio Comisso
I have a problem running starcd 4 on more than one node. It look for a file .starboot.run that is in a directory that is local and not nfs-mounted . How can I change the path for this file?
This is the rror message
PNP: Assigned "pantarei-0-31.local,4 PNP: Spawning STAR processes on multiple nodes (cluster). bash: /tmp/starboot-cuma@pantarei-0-31.local.11712/.starboot.run: No such file o r directory Killed by signal 2. Killed by signal 2. Killed by signal 2.
Regards Alessio
Old   April 10, 2008, 12:33
Default Re: Problem with starcd in parallel
TG
Are you starting your job from a directory that is NFS mounted to all the compute nodes with the exact same path? If not you need to, and if you already are, then its something else.
Thread Tools
Trackbacks are On
Negative Density problem in starcd Dinesh CD-adapco 4 January 26, 2009 13:53
StarCD v4 *.pstt file problem Rotan CD-adapco 3 September 17, 2007 05:01
StarCD display problem cfddummy CD-adapco 3 April 9, 2007 16:59
Problem with Starcd V 3.22 and 3.24 Amarjeet CD-adapco 2 October 25, 2005 12:50
Convert from StarCD 3.10 to StarCD 3.15 Jing CD-adapco 1 April 17, 2002 09:22
