pressure drop Star-CCM+
Like Tree1Likes
  • 1 Post By arulnambi_palani
Old   April 14, 2008, 10:11
Default pressure drop Star-CCM+
norbinou
How can I the pressure drop in Star-CCM+.
Thanks
Old   April 14, 2008, 20:11
Default Re: pressure drop Star-CCM+
Name
dP=Pin - Pout
Pout=0 Pa, as Default >> if your outlet pressure is equal to the reference pressure (atmospheric pressure)
so dP=Pin
Your avaraged inlet boundary will give you pressure drop ..
Create plot as Area Avaraged.. select your part as inlet boundary, select Pressure as Scalar Value.. then right click and Create Plot and Monitor from Report.. you will get the pressure drop vs the iterations..
Old   April 15, 2008, 05:24
norbinou
Thanks
I check it. I'm a new beginner in ccm+, after it was easy in Star-CD. Reference pressure and reference cell under Monitoring (Star-guide).
Nevertherless thanks, and what about flow split outlet?
Old   April 15, 2008, 06:31
norbinou
ok I check it. The result give only the static pressure drop. I want the total pressure drop.
Please who can I calculate the total pressure drop?
Thanks CFD users
Old   April 15, 2008, 16:35
Name
select the total pressure option as scalar
Old   June 4, 2019, 05:48
Default Starccm simulation plots
Jalvathi
jalvathi is on a distinguished road
Hello All,
I am not very new to Starccm simulations. But the current project in which I am working needs to plot the Pressure drops at various surface areas.
My colleague have already run the simulations and the mass flow averaged reports is created and from that the monitor and plot have been created for all the surface areas which are needed.
I need to plot the pressure drop in the Y axis with the surface area names in the X axis, so that I can show the Pressure drop at various sections.
Can anyone help me to create the Graph?
Thanks and regards,
Jalvathi.
jalvathi is offline   Reply With Quote
Old   July 19, 2019, 04:09
Arulnambi Palani
arulnambi_palani is on a distinguished road
Originally Posted by jalvathi View Post
Hello All,
Thanks and regards,
Jalvathi.
Hey Hi,
I hope your Problem is already sorted out. If not, then this would help you. Since the montiors for all Surface Areas are already done. Just Export those Monitors and average the values. Then you would get for each Surface area, a pressure value.
Finally in Excel, you can plot These values versus Surface names.
Thanks,
Arul
jalvathi likes this.
arulnambi_palani is offline   Reply With Quote
Old   November 21, 2019, 01:35
Max Irving
maxirving is on a distinguished road
select the total pressure option.
lenny face
maxirving is offline   Reply With Quote
Old   March 10, 2023, 04:04
Javier Marquinez
AnonymousCR7 is on a distinguished road
Originally Posted by Name
;175647
dP=Pin - Pout
so dP=Pin
Good morning,
In case I don't know the outlet Pressure, but I have constrained the mass flow, how could I be obtaining a Pressure drop btw inlet and outlet of 340 Pa, while setting an average pressure values on inlet and outlet, I obtain 30 and -1000 Pa.
Isn't the pressure drop the difference btw these average pressure values?
Thanks in advance
AnonymousCR7 is offline   Reply With Quote
Old   March 10, 2023, 05:09
cwl
Chaotic Water
cwl is on a distinguished road
Pressure Drop Report.
cwl is offline   Reply With Quote
Old   March 10, 2023, 05:28
Javier Marquinez
I know, I know, the pressure drop report is the one giving 340 Pa. However, if I look to the pressure values at both locations are more similar to those obtained in the surface average values.
Old   March 10, 2023, 05:35
cwl
Chaotic Water
Which pressure values at both sides - Static Pressure or Total Pressure?
Old   March 10, 2023, 06:40
Javier Marquinez
Yeah, okay solved.
Thank you very much for your help.
What type of pressure can give the pressure drop david FLUENT 1 February 17, 2014 11:51
Pressure drop Paul_C FLUENT 3 November 17, 2012 08:50
pressure drop jay Main CFD Forum 1 September 24, 2008 09:27
pressure drop wilson FLUENT 1 August 2, 2006 18:34
pressure drop margaret mkhosi FLUENT 1 January 17, 2006 06:45
