Home > Forums > CD-adapco
pressurization of a volume
Old   April 14, 2008, 10:23
Default pressurization of a volume
jma
I am trying to model the pressurization of a volume once a valve is opened. I am running a transient model and for the duration of the simulation there is only the inlet from the valves. I have tried using a pressure boundary which does not seem to be give me the results I want and with the inlet boundary condition it does not seem like the pressures between the two volumes equalize. Any suggestions on setting the correct boundary conditions? Thanks in advance.
Old   April 16, 2008, 14:23
Default Re: pressurization of a volume
jma
I just wanted to clarify this problem. I am using the mass flux option to define my inlet BC. I understand that the density and velocity components are used to find the constant mass flux. The density I am using represents the density of the air at the pressure at the inlet BC. This BC does not seem like it will get me the results I want since the pressure between the two volumes will not equalize but rather continue to increase in the one volume since the mass flux is constant. Any suggestions on setting the correct pressure BC or if this is possible using an inlet BC?
Thread Tools
Trackbacks are On
zero volume 3DmaniacSLDWRKS FloEFD, FloWorks & FloTHERM 0 March 4, 2009 17:20
How to set a volume? jane FLUENT 0 January 21, 2009 02:00
Volume Carl FLUENT 0 November 28, 2008 07:28
How to create a fluid volume inside a solid volume sanin FLUENT 4 November 13, 2008 16:17
fluid hot volume in fluid cold volume zahid FLUENT 4 June 1, 2002 09:11
