parallel CCM+
Old   April 15, 2008, 11:20
Default parallel CCM+
tom
I am using a quad core processor and would like to use its max processing power. If I do a serial simulation I can only use 25% of total CPU. However, if I make the simulation parallel and increase the number compute processes to, say, 2 I then for a few minutes I get full throttle until I get a "memory access exception".
Does this mean multi-core can only run serial simulations, or is the fact that I am running 32 bit XP hinder progress.
Thanks for any help
Old   April 15, 2008, 12:48
Default Re: parallel CCM+
Jim
Have you got parallel licenses?
Old   April 15, 2008, 13:44
tom
I have been told that we do. But as this is my first time doing this I will let the support guys guide me.
Quad-core seems to be of little benefit for speeding up simulations in serial. Its a shame tom
Old   April 15, 2008, 13:46
Jim
Serial is Serial whatever chip you use, I wouldn't recommend running on all four cores anyway, you will actually run slower than on 3 due to the memory bus becoming overloaded
Old   April 17, 2008, 05:46
Thomas
Hi, I have similar problem running STAR-CD V3.26 on DualCore cpu. I got very often a memory access error and simulation stops on 2nd cpu. I could solve most of these problems when disabling the AMG solver. But some cases still do not want to run in parallel. Info: 32 bit windows Xp prof. 4GB RAM ( I know, I cannot adress the full 4GB, but above describes problem occur even on relativly small cases which definitly fit into 2GB!!)
So my only advice: try to run the case with CG-solver. maybe it works ;-) Thomas
Old   May 8, 2008, 19:54
Dan
I run a parallel system with quad core, 64 bit linux and 10Gb Ram, never have had any memory access errors unless StarCCM corrupts my simulation file (does happen frequently, I've never had problems exporting my mesh, re-setting up analysis if I get in a bind). Without knowing any more about your system, I would guess there's a conflict in your setup, I'd advise against 32 bit Windows for CFD work.
Parallel UDF Karo FLUENT 2 April 25, 2017 02:36
Where is my Parallel Log andrewburns OpenFOAM Running, Solving & CFD 5 February 5, 2008 00:07
udf parallel Phil FLUENT 4 May 28, 2004 20:49
cfx parallel Rao CFX 7 April 17, 2004 00:53
Parallel run Bogdan Siemens 2 June 26, 2002 11:31
