Sphere in STAR-CD
Old   April 10, 2008, 01:56
Default Sphere in STAR-CD
sameer jaju
Hi, I am creating a simple sphere in STAR-CD. I can create it with the sperical coordiates system. After creation, when I go to check cells, it shows negative volume error. I did check for left and right handed cells and then made all right handed. But then it shows some crack errors. After that if I use VMERGE ALL , message comes.. vertices deleted. Then my whole geometry vanishes. And if I check by COUN CELLs, the message shows the celltype and number of cell and number of cell in cplot as expected. still I can not see geometry. Please let me know if anybody knows how to remove error in Sphere in STAR-CD. Thank you in advance
Sameer
Old   April 11, 2008, 00:14
Default Re: Sphere in STAR-CD
Sachin
I am having the same problem. I can generate the sphere. Then flip to right handed cells and I create the couple. I do have 'crack' error which means unconnected regios. can anyone help me for this.
sachin
Old   April 11, 2008, 03:18
Joern Beilke
You will find the corret way of meshing a sphere on
http://www.beilke-cfd.de/sphere.mdl.gz
Using the "vd3d" command in a spherical coordinate system is crap.
Creating the mesh in prostar requires the use of blocks and some smoothing. This mesh was created using GridPro within 2 minutes.
Old   April 11, 2008, 03:56
Joern Beilke
For those who have to use ProStar:
cdel all
vdel all
ctdel 4 20
ctype 1
csys 1
vc3d -0.5 0.5 10 -0.5 0.5 10 -0.5 0.5 10
cset all
live surf create
cset news type 4
vcex 10 ,, cset ,,, norm 0.05
cset news type 4
cdel cset
cset news flui
live surf create
cset news type 5
vset none
vell 15
loca 10 sphere
vset news cset
vmod vset 1
cset news type 1
vell 200
cplo
Old   April 11, 2008, 11:17
Sachin Patil
Thanks Joern. I appreciate it.
Sachin
Old   May 5, 2008, 08:37
Boris
Hello, I had the same thing in torroidal C.S. - I guess it was incorrect determination of radius (-r,r) of angles. If you try to play with these parameters you can get what you need.
Importing Sphere from STAR-CD Sachin Siemens 12 April 29, 2008 17:59
sphere deformation Frackowiak FLUENT 0 May 15, 2007 10:30
cd of sphere senthil FLUENT 3 June 1, 2006 05:22
Sphere tie FLUENT 0 July 5, 2005 14:29
