importing surface from Pro/E
Old   April 21, 2008, 12:53
Default importing surface from Pro/E
Sachin
I am well familiar with Pro-STAR but not with importing the geometries into Pro-STAR. I did create geometry in Pro/E and did save it as .iges file. I opened it in Pro/E surfaces and mesh it. Then I export from Pro/E surfaces as .STL format and finally imported it in Pro-STAR with import grid option in stl format. I can see the shells. I am familiar with the VCEXTRUDE command to convert shells (with single surface) into Fluid or solid cells. How do I convert shells having more than one surface (I got 6 surfaces)into fluid or solid cells.
Thank you for your time and consideration.
Sachin
Old   April 21, 2008, 13:03
Default Re: importing surface from Pro/E
allan
hi
did you check your file in prosurf?
you can create a closed triangulated surface in here, and mesh it in proam
alternatively star-cd has a proe pluggin
allan
importing unmeshed surface from gambit to fluent NISHIKANT TAMRAKAR FLUENT 1 March 7, 2009 14:08
Importing Geometry CC CFX 1 July 16, 2008 12:45
3D CFD importing corey FLUENT 4 January 29, 2008 16:26
Surface tension - Continuum Surface Force model Robert Main CFD Forum 0 May 2, 2002 07:34
importing cad/surface informations Roberto Ciardulli Siemens 0 December 12, 2000 03:28
