Home > Forums > CD-adapco
Importing Sphere from STAR-CD
Old   April 22, 2008, 15:44
Default Importing Sphere from STAR-CD
Sachin
I made a sphere in Pro/E and then did save it as .stl format. I did import this geometry in .stl format in STAR-CD and it was successful. Now the imported geometry is not solid or fluid cells as expected. The spehre shows only as shells. My question is how to convert these shells into Solid or FLuid cells. Most often to convert reactangular shells into solid or liquid cells we try the VCEXTRUDE command which works fine. But here which command and how it should be used.
Thank you for your time and consideration.
Sachin
Old   April 22, 2008, 16:34
Default Re: Importing Sphere from STAR-CD
allan
hi
why are you creating a sphere in proe and reading it into prostar? Why don't you just create a semi circle in prostar on the x-z plane with shell cells and extrude it in a cylindrical coordinate system (csys 2) into a sphere.
If you really want to do it in this way them you need to use proam to generate a volume mesh from a surface mesh.
allan
Old   April 22, 2008, 17:54
Sachin
Thank you for your reply allan. Actaully I do not have Pro/amm . Will now try creating semi circle. Anyways. Thanks. I will keep you updated.
Sachin
Old   April 22, 2008, 17:58
Joern Beilke
Why are you not using my macro to create the volume mesh?
Old   April 22, 2008, 19:52
Sachin
Dear Joern, Thank for the reply. I am sorry to say that your macro gives me the error and I can not move forward due to that. I would appreciate if you would take a look into that macro again and plz run the "check utility" after you are done. I am not able to remove those errors.
Thanks
Sachin
Old   April 22, 2008, 20:18
Sachin
Dear Allan,
How to extrude a semicircle in cylindrical coordiate system into a sphere.
I am new to these types of things.
Thanks.
Sachin
Old   April 23, 2008, 03:04
Joern Beilke
Which one does not work? The "sphere" or the "sphere in cube"?
Old   April 23, 2008, 03:20
allan
change to the cylindrical co-ord system
csys 2
then
vcex <args>
when it asks for a cell range use cset,,,
Help vcex for info
allan
Old   April 23, 2008, 03:21
allan
ok, no problem
allan
Old   April 23, 2008, 10:37
sachin
Thanks for the reply Allan. I will try out that too.
Dear Joern, the " sphere" works fine. I have problem in " Sphere in Cube". I would appreciate if you could check it again. I did try my own for quite some time then I gave up. Thanks a ton ,Joern.
Sachin
Old   April 23, 2008, 12:17
  #11
Joern Beilke
What about this proposal:
http://www.cfd-online.com/Forum/starcd.cgi?read=14306
Have you checked that.
Old   April 23, 2008, 21:29
  #12
sachin
yes. I did check that comment.Thanks for your promt reply. Actually the problem is with the connectivty of the cells. In my another try I neither used solid cells nor refined any cells. All cells are fluid cells. I did increase the cells for the very first block as you suggested. The result is spehre in cube. When I run the check grid option, the error is connectivity error and it says same face orientation when I try to write geometry files.
Have you tried at your end and is that working successfully? Have you run the " check grid " to seee what is the result?
Thanks... Sachin
Old   April 29, 2008, 17:59
  #13
Andrea
Have you tried to create a sphere from the Star-GUI 3d meshing tool panel? There you can choose a spherical csys and create a sphere at the moment...is that correct? I've tried to do that and I get a sphere...my only problem is for concave cells in the heart of the model...
Thread Tools
Trackbacks are On
Importing Star-CCM+´s .ccm file in Star-CD Zolet CD-adapco 7 November 26, 2008 14:57
Sphere in STAR-CD sameer jaju CD-adapco 5 May 5, 2008 08:37
Cracks - importing a Mesh into Star-CD from CCM+ mk_mat CD-adapco 5 December 1, 2007 18:07
Format for importing Plot3d files into Star-CCM+ Meredith CD-adapco 1 October 12, 2005 12:28
Errors importing Gambit .neu files to Star v3.15 Cb CD-adapco 1 November 29, 2004 13:39
