How can I calculate equivalence ratio?
Old   April 27, 2008, 21:10
Default How can I calculate equivalence ratio?
Duan J Q
When simulate diesel engine, equivalence ratio is an important parameter. But how can I calculate it?
Can anybody tell me?
Thanks for any help you can give me.
Old   April 29, 2008, 04:09
Default Re: How can I calculate equivalence ratio?
Mac
Equivalance ratio is the ratio of Air-fuel mixture (stoic) to the Air-fuel mixture (actual). Hope this helps - Mac.
Old   April 29, 2008, 17:50
Andrea
As Mac said the equiv. ratio is air-to-fuel stoich / air-to-fuel actual...depending on the combustion model that you use you have different way to get the correct mass concentration to calculate the air-to-fuel ratio.
Old   May 6, 2008, 02:51
Duan J Q
The model what I use are:
1 Turbulent flow model: standard К-ε
2 Droplet Break-Up Model: Reitz/Diwakar
3 Spray impingement model: Bai's
4 Ignition model: shell
I want to know only steam or liquid and steam reckon in fuel?
And when I calculate air, air is equal to subtract fuel from cell mass or O2+N2+CO2+H2O or O2/0.233 or some way else?
Old   May 15, 2008, 18:23
Andrea
Use only the mass of fuel vapor and the mass of air...calculated by means of m_02/0.233
Old   May 21, 2008, 02:44
sankar
Hi i too need to calclulate Equivalence ratio..The pecentage of exhaust gases and composition are given..The Stoichiometric A/F ratio is known but i dunno actual A/F ratio..Can i find out the equivalence ratio from chemical equations..could anyone help me
sankar
Hi.. i too need to calclulate Equivalence ratio..The pecentage of exhaust gases and composition are given..The Stoichiometric A/F ratio is known but i dunno actual A/F ratio..Can i find out the equivalence ratio from chemical equations..could anyone help me
Old   June 7, 2008, 12:40
Andrea
You must calculate the actual A/F ratio from the output of your simulation...?!
Use command getc to load the mass of fuel vapour in each cell and to load the mass of oxygen in the same cells. Then you can calculate the locale A/F ratio and the local equiv. ratio.
Bye
Old   May 29, 2022, 12:01
kd@34 is on a distinguished road
Equivalence ratio(\lambda) = Actual air-fuel ratio/stoichiometric air-fuel ratio
you can see more details about equivalence ratio here
you can calculate stoichiometric air-fuel ratio by balancing chemical reaction of fuel with oxidizer or it can be also calculated from elemental composition of fuel. You can also use online calculators like this.
kd@34 is offline   Reply With Quote
Who can help me about equivalence ratio? Duan J Q Siemens 5 May 15, 2008 18:17
diesel spray combustion equivalence ratio usker Siemens 12 March 1, 2008 06:09
How can I calculate the air-fuel ratio? lizhihua Siemens 1 August 22, 2006 00:45
equivalence ratio Antony Siemens 1 November 18, 2005 10:59
Distribution of Phi (Equivalence ratio) Mahbub Siemens 3 January 5, 2004 00:47
