Non-zero side area
Old   May 5, 2008, 06:55
Default Non-zero side area
subramani
While running a transient analysis with moving mesh, I am getting the following kind of error. Will it affect the solution. How to avoid the kind of error?
WARNING #113 *** CELL 10238 BEING REMOVED HAS NON-ZERO SIDE AREAS - CHECK IN PROSTAR FOR POSSIBLE MESH MOVEMENT ERROR
*** WARNING #113 *** CELL 10238 BEING REMOVED HAS NON-ZERO SIDE AREAS - CHECK IN PROSTAR FOR POSSIBLE MESH MOVEMENT ERROR
Thanks in advance
Old   May 6, 2008, 07:13
Default Re: Non-zero side area
Anton Lyaskin
This means that the cells you're removing are not fully collapsed. Try to make a preview run with mesh motion only (i.e. no flow field simulation). For this set RCONST 4 to 1.0
Old   May 12, 2008, 02:02
subramani
Hi Anton,
Thanks for your reply.Can u explain me how to preview the run with mesh motion & To set the RCONST value, whether I need to type the same in Pro/star output window?
Old   May 12, 2008, 23:43
subramani
Hi anton,
As you said i did preview run with mesh motion by setting RCONST 4 to 1.0. After completion of run, if I check in the info file, following warning message displayed
*** WARNING #113 *** CELL 17 BEING REMOVED HAS NON-ZERO SIDE AREAS - CHECK IN PROSTAR FOR POSSIBLE MESH MOVEMENT ERROR"
I run the cold flow simulation(Only compression stroke simulation) using time step as 0.25 deg.simulation completed & I was able to see the results like velocity,pressure distribution.Pressure values obtained fro the simulation are not matching to the calculated value.
But still there is a warning message mentioned above in the info file.
Old   May 15, 2008, 05:32
Anton Lyaskin
The idea of mesh preview run is to check visually your mesh at every time step. So before running the mesh preview you need to turn on writing the results to transient post file (pstt) at every time step. After this you will be able to see the actual condition of your mesh at the desired moment of time (don't forget to turn on Moving Mesh option when loading pstt file). Look at cell 17 to check weather it's fully collapsed at moment of its removal.
Periodic boundary for side walls jiju CFX 2 February 3, 2008 17:24
Side channel pump simulation mohammad CFX 0 June 3, 2007 11:16
Fluent side work BJ FLUENT 0 June 23, 2006 16:48
Grap Fluid Cells Just On One Side Of A Baffle Tommy Siemens 0 May 7, 2006 07:49
HEX flow in air-side Chetan Kumar Main CFD Forum 1 May 2, 1999 01:36
