starcd 3.24 has bugs?
Old   May 13, 2008, 07:56
Default starcd 3.24 has bugs?
whitemelon
I did a transient simulation of the exhaust system of engine by starcd 3.24, the negative density appeared when the first step was over.The time step is 2.7778e-5,the engine speed is 6000rpm,the mesh is all hexa by ICEMCFD.There's no effect on convergence by adjusting the relaxation factor and pressure correcter factor,I have no idea of changing the situation. But a strange sign occured when i used the star cd 3.15 for the simulation, the negative density disappeared, i don't know why?
Old   May 14, 2008, 08:03
Default Re: starcd 3.24 has bugs?
Will
Try upgrading to the the latest verion (3.26 or 4.06) 3.24 is a few years old now
Old   May 16, 2008, 00:42
whitemelon
The problem also exist when i use starcd 3.26.
Old   May 16, 2008, 01:47
Joern Beilke
"switch 60 on"
Old   May 16, 2008, 08:16
whitemelon
"switch 60 on" ,wha't the mean?
Old   May 16, 2008, 09:33
Joern Beilke
Just enter the command into prostar an see if it works.
Old   May 16, 2008, 10:44
whitemelon
switch on 60,it doesn't work.
Bugs in fvcsurfaceIntegrate su_junwei OpenFOAM Bugs 4 July 7, 2013 10:29
Bugs in FFT luca OpenFOAM Bugs 2 January 27, 2009 15:40
Wiki - Bugs Andy R Main CFD Forum 0 July 25, 2008 13:15
bugs in starcd 4.06 whitemelon Siemens 0 July 11, 2008 06:26
Bugs in polySplineEdgeC kbr OpenFOAM Bugs 2 June 6, 2008 13:04
