Tutorial 13 in version 3.26.004 - simple ICE
Old   May 16, 2008, 23:00
Default Tutorial 13 in version 3.26.004 - simple ICE
Luke
I am fairly new to Star-CD. I need to do a simple model of an ICE for a project I'm doing but I don't have access to es-ice. I have been going through tutorial 13 in version 3.26.004 but am stuck at the part where it says to run the analysis. Under the "CFD Analysis (STAR)" heading it says to type star into the STAR-CD session window. Which window is this? I tried typing it in the pro-STAR output window but that clearly isn't it. Any help will be very much appreciated.
Old   May 17, 2008, 03:22
Default Re: Tutorial 13 in version 3.26.004 - simple ICE
Parthiban
are you running your model in windows or LINUX
If windows..
In the STAR GUIDE panel go to ANALYSIS PREPARATION/RUNNING and then to RUN ANALYSIS INTERACTIVELY .the you can see start new analysis.
If LINUX...
Same thing can be done.. but if you bring the model form ES-Ice then go to terminal and then working directory and type STAR -dp
Old   May 17, 2008, 08:11
Luke
Oh ok. The tutorial intructions must assume that you are using LINUX. I thought that maybe I couldn't got to RUN ANALYSIS INTERACTIVELY because it is a moving mesh problem as the other tutorials say to do this but 13.1 does not. I guess the person who wrote 13.1 assumed the user was using LINUX. Thanks very much for your help!
Old   May 17, 2008, 23:36
Luke
I just tried that and it says "Moving grid analysis cannot be run interactively through pro-STAR. Use batch mode". Can someone please tell me what batch mode is?
Old   May 18, 2008, 14:30
parthiban
Ok..
Batch mode is nothing but running without graphical interface.
you can run that using the button available in starlaunch window. (the one you use to go to prostar). set the working directory first and then run the solver.
New version fluent file open in Old version ? MANOJKUMAR FLUENT 2 July 10, 2013 04:43
Incomplete flangeans tutorial for laplacianFoam in tars for version 141 gschaider OpenFOAM Bugs 1 September 4, 2007 13:53
[blockMesh] Tutorial for Creating Simple 3D Meshes jonlemur OpenFOAM Meshing & Mesh Conversion 4 August 8, 2007 13:20
Tutorial is not running on star-CD version 3.2 Arnab Siemens 0 August 30, 2004 15:43
where to find old version Fluent tutorial guid Roger FLUENT 0 March 11, 2002 17:04
