July 4, 2008, 00:56 |
MRF query
I have one basic doubt for rotating flows. let's say I have to doflow analysis of a turbine. I will be having one stationary domain (stator) and one rotating domain(rotor). I am using MRF Suppose my rotor is rotating at 50000 rpm. Then am I required to apply rotation to walls of blade . My doubt is whether blade walls remain stationary or not? Is it stationary wrt rotating region? So, I can do two things. (1) Apply 0 rpm in relative frame. (2) Apply 50000 rpm in absolute frame. Which one is right?
Kindly let me know the answer. |
July 4, 2008, 05:24 |
Re: MRF query
If you solve rotor region on the rotating frame, then the blade should have velocity relative to that frame. In your case, it is zero.
FSI query | CC | CFX | 2 | September 1, 2008 01:31 |
MRF query | sandip | FLUENT | 3 | July 4, 2008 05:17 |
DPM query | DPM_fluent_user | FLUENT | 0 | June 23, 2008 12:13 |
query | rajesh kumar gupta | FLUENT | 0 | October 9, 2007 17:44 |
Query | Andy | FLUENT | 3 | January 31, 2006 01:48 |
