-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   Cluster Linux+OpenMOSIX with STAR-CD (http://www.cfd-online.com/Forums/cd-adapco/56670-cluster-linux-openmosix-star-cd.html)
CFD_User June 17, 2008 06:34
Dear all, I'm looking for some feedback by someone that uses STAR-CD on a Cluster Linux+OpenMosix.
There is anyone around the world that works with this platform?
Thanks in advance for your contribute.
CFD_User
Ketal June 17, 2008 18:46
Re: Cluster Linux+OpenMOSIX with STAR-CD
you need to ask your account manager for this. He should know this
TG June 17, 2008 21:41
The account manager is going to say that CD-adapco supports Red Hat Enterprise and Suse Enterprise. Any other version of linux and you are on your own.
CFD_User June 18, 2008 03:31
I'm still waiting the answer also from national account manager even though this is not what I asked for. I would need an evidence that some STAR-CD user experienced a full functionality and good performance of STAR-CD installed on a Linux-Cluster working with the OpenMOSIX kernel patch that should handle in a perfect way all parallel process.
Thank you for your attention Ketal and TG.
CFD_User
BastiL June 19, 2008 14:21
I am just wondering why you want to use OpenMOSIX. I have never tried it but I don't think its a good idea. Th eroject is dead.
Regards.
CFD_User June 20, 2008 04:33
Checking the site http://www.mosix.org/ it seems that the platform is still available.
Some papers about this platform sounds interesting arguments related to perform CFD on HPC.
Bye.
CFD_User
BastiL June 20, 2008 14:25
Yes available but no longer developed. If you have a cluster why not run it in a conventional way?
CFD_User June 25, 2008 09:43
BastiL, what do you mean for "conventional way"?
CFD_User
matej July 1, 2008 02:34
I think, that the best way how to find out is to try. People from adapco will never say yes to systems they are not working with. So at the end you'll have to try yourself anyway. Personally I know Star-CD runs on derivatives of RedHat like OpenSuse, Cent-OS, as well as on debians or gentoo. I do not think you can get much from the system itself, it is the network and version and tuning of MPI where you can gain some speed. But this is only my believe. I'm not any cluster guru.
Matej
ANISH DESAI July 22, 2008 04:52
RFQ
PROFESSIONAL INDUSTRIAL ENGG. CO. Satya Kripa, Cama Lane, Hansoti Lane, Ghatkoper (w) MUMBAI - 400 086. INDIA CELL NO.:- 9821833223, CONTACT NO.: 00 91 22 65279364 FAX NO. : 00 91 22 25139420 E-MAIL : anishdes@gmail.com, headpiece@gmail.com
REF. NO. ANS466/2008 DATE : 19 JUNE 2008
Dear sir,
KINDLY QUOTE YOUR PRICES WITH TERMS / CATALOGUE ETC.
LINUX CLUSTER
SPECIFICATIONS :-
HPC SERVERS :- PROCESSORS : DUAL PROCESSOR QUAD CORE INTEL XEON @ 3.0GHZ OR HIGHER WITH 12 MB CACHE WITH FSB 1333 MHZ MOTHERBOARD : RACK OPTIMIZED COMPATIBLE BOARD WITH INTEL CHIPSET AND DUAL PROCESSOR SUPPORT MEMORY : 16 GB FB DIMM 800 MHZ DDR2 RAM, MEMORY PROTECTION, MEMORY MIRRIORING WITH ADVANCED ECC CAPABILITIES HDD : 250 GB OR HIGHER NON-HOT PLUG ENTERPRISE SATA HARD DISK NETWORK : DUAL PXE BOOT COMPLIANT EMBEDDED PCIE 1000BASET GIGABIT SERVER ADAPTERS INFINIBAND : SINGLE PORT 4 X DDR (20 GBPS) INFINIBAND PORT EITHER ON-BOARD OR PCI EXPRESS, LOW PROFILE HOST CHANNELS ADAPTER, 1 AUTO-SENSING 1X /4X INFIBIBAND PORTS DISPLAY : ON-BOARD DISPLAY ADAPTER PORTS : 1 SERIAL, 2 USB FORM FACTOR : 1U RACK MOUNTABLE WITH RAILKIT CHASIS : 1U RACK MOUNTABLE CHASIS WITH RAILKIT RECOMMENDED FOR THE MOTHERBOARD MANDATORY BIOS FEATURES : PXE COMPLIANT BOOT PROCEDURE CONSOLE REDIRECTION TO SERIAL PORT FAN CONTROL FOR LOW NOISE BIOS FEATURE TO BOOT FROM USB, NETWORK POWER-ON MODE : ON STATE OR PRIOR " TO " POWER LOSS STATE SERVER MAMAGEMENT SYSTEM : THE MOTHERBOARD SHOULD HAVE AN IPMI 2.0 OR HIGHER COMPLIANT BUILT-IN SERVER HEALTH MONITORING SYSTEM TO MONITOR THE VOLTAGE AT DIFFERENT POINTS, CPU AND SYSTEM FAN SPEEDS AND CPU AND CHASSIS TEMPERATURES. MONITORING SOFTWARE TO RUN ON RHEL 5 OR HIGHER. OS COMPATIBILITY : RED HAT ENTERPRISE LINUX 5 OR HIGHER FOR X86_64 ARCHITECTURE PERFORMANCE : 45 GFLOPS OR HIGHER WITH THE HIGH PERFORMANCE LINPACK BENCHMARK
FILE SERVER :- DISK SPACE : 2 TB OR HIGHER WITH RAID 5 WITH 15KPRM SCSI OR SAS HOT PLUGGABLE HARD DISKS WITH RAID LEVEL 5 WITH RAID CONTROLLER HAVING 512 M CACHE RAM PROCESSORS : DUAL PROCESSOR QUAD CORE INTEL XEON (EM64T) @ 3.0GHZ OR HIGHER WITH 12 MB CACHE WITH FSB 1333 MHZ MOTHERBOARD : RACK OPTIMIZED COMPATIBLE BOARD WITH INTEL CHIPSET AND DUAL PROCESSOR SUPPORT MEMORY : 16 GB FB DIMM ECC 800 MHZ DDR2 RAM NETWORK : DUAL PXE BOOT COMPLIANT EMBEDDED PCIE 1000BASET GIGABIT SERVER ADAPTERS INFINIBAND : SINGLE PORT 4X DDR (20 GBPS) INFINIBAND PORT EITHER ON-BOARD OR PCI EXPRESS, LOW PROFILE HOST CHANNEL ADAPTER, 1 AUTO-SENSING 1X /4X INFIBIBAND PORTS. OPTICAL DRIVE : DVD +RW 16X HALF HEIGHT PORTS : 2 USB, 1 SERIAL CHASIS : 5U RACK MOUNTABLE CHASIS WITH RAILKIT I/O : STANDARD KEYBOARD, MOUSE, 21 INCH TFT MONITOR OS COMPATIBLY : RED HAT ENTERPRISE LINUX 5 OR HIGHER FOR X86_64 ARCHITECTURE SPARE HDD : ONE SPARE SCISI OR SAS HOT PLUGGABLE HARD DISK IDENTICAL TO THE ONES ALREADY PRESENT IN THE SYSTEM BACKUP : ULTRIUM 3 LTO 400/800 GB TAPE DRIVE INTERNAL TAPES 10X400 GB COMPATIBLE TAPE CARTRIDGES AND 1 CLEANING MEDIA REMOTE MANAGEMENT : VIRTUAL TEXT REMOTE CONSOLE, REMOTE SERIAL CONSOLE, OS INDEPENDENT HARDWARE HEALTH STATUS ETC.
GIGABIT SWITCH :- PORTS : 48 RJ45 10 /100 /1000 MBPS PORTS BANDWIDTH : FABRIC BANDWIDTH 96 GBPS FORM FACTOR : 1U RACK MOUNTABLE MANAGEMENT INTERFACE : LAYER 3 SWITCH, COMMAND LINE INTERFACE THROUGH A TELNET SESSION, SNMP AND WEB BASED INTERFACE
INFINIBAND SWITCH :- PERFORMANCE : 20 GBPS (4X DOUBLE DATA RATE IN EACH DIRECTION) OR BETTER BANDWIDTH UP TO 960 GBPS PORTS : 24, CX4 COPPER MEDIA SUPPORT CABLES : 25 INFINIBAND CX4 COPPER CABLES, 12 PAIR MICROGIGACN COPPER FORM FACTOR : 1U RACK MOUNTABLE PROTOCOL SUPPORT : IPOIB, MPI, SDP, SRP INITIATOR, ISER. MANAGEMENT INTERFACE : IB NETWORK MANAGEMENT SOFTWARE SOFTWARE : RED HAT ENTERPRISE LINUX 5 OR HIGHER FOR X86_64 ARCHITECTURE POWER : 2 HOT SWAP POWER SUPPLIES
DESKTOP PCS :- PROCESSORS : CORE 2 DUO E6850 (4MB L 2 CACHE 3.0GHZ 1333 MHZ FSB) OR BETTER MOTHERBOARD : COMPATIBLE INTEL MOTHERBOARD MEMORY : 4 GB DDR2 800 MHZ HDD : 250 GB SATA HARD DISK NETWORK : ON BOARD GIGABIT MONITOR : 22 INCH LCD TFT I/O : STANDARD KEYBOARD /OPTICAL MOUSE OPTICAL DRIVE : DVD WRITER GRAPHICS CARD : NVIDIA GEFORCE 8800GTX 512 MB PCIE GRAPHICS WITH SLI
RACK MOUNTABLE UPS :- CAPACITY : 3000VA FORM FACTOR : 3U RACK MOUNT WITH BATTERIES POWER OUTPUT : 8 NOS. IEC 320 C13 (10A) AND 2 NOS. IEC 320 C19 (16 A) OR MORE BACKUP TIME : 30 MINUTES AT HALF LOAD OR BETTER INTERFACE PORTS : MANAGEMENT OVER NETWORK USING TELNET, HTTP, HTTPS, SSL, SNMP, PROTOCOLS AND FACILITY OF ALERTS BY SYSLOG, EMAIL AND SNMP PROTOCAL AND FACILITY OF ALERTS BY SYSLOG, EMAIL AND SNMP TRAPS ACCESSORIES : SIGNALLING RS-232 CABLE, WEB/SNMP MANAGEMENT CARD WITH TEMPERATURE MONITORING POWER CARDS : POWER CORDS FOR EACH PORT DISTRIBUTING POWER FROM UPS TO THE SYSTEMS SOFTWARE : RED HAT ENTERPRISE LINUX 5 OR HIGHER FOR X86_64 ARCHITECTURE
INDUSTRY STANDARD RACK :- RACK : WIDE ENCLOSURE WITH INCREASED CABLE MANAGEMENT OPTIONS USABLE HEIGHT : 42U DIMENSION : 600MM (WIDTH), 1000 MM (DEPTH) AND 2000 MM (APPROX. HEIGHT) MAX. DEPTH : 1070 MM STREGTH : 1000 KG STATIC LOAD SPECIFICATIONS : REAR AND FRONT PERFORATED DOORS WITH 80% PERFORATION TOP COVER VENTED BOTTOM GLAND PLATE ADJUSTABLE LEVELING FEET NUMBERED U POSITIONS ON BOTH FRONT AND REAR RAILS HOLES FOR CABLING AT THE TOP AND BOTTOM HEAVY DUTY CASTORS (PLAIN 2 NOS WITH BRAKE 2 NOS.) 4 NOS. OF 90 CFM FANS MOUNTED ON TOP COVER EARTHING BAR WITH 200 A GROUND CURRENT CAPACITY 2 NOS. OF 32 A SWITCHED RACK PDUS MOUNTED ON TOP VERTICALLY (ZERO U) WITH EACH PDU HAVING AT LEAST 20 NOS. OF IEC 320 C13 INDEPENDENTLY SWITCHABLE OUTLETS NETWORK CONNECTIVITY, POWER SEQUENCING SNMP, TELNET, SSH COMMAND LINE INTERFACES EMAIL ALERTS CABLE MANAGERS : THREE 100MM VERTICAL CABLE MANAGERS MOUNTED IN THE REAR SIDE NUTS & SCREWS : RACK MOUNT CAGE NUTS AND SCREWS WITH PLASTIC/NYLON WASHERS : 160 NOS. BLANKING PANELS : 20 NOS. OF 1 U BLANKING PANELS MAKE /MODEL : APC NETSHELTER SX OR EQUIVALENT
RACK MOUNT KVM SWITCH :- PORTS : 32 PORTS WITH PS/2 AND USB KEYBOARD AND MOUSE FEATURES : INTEGRATED WITH 17 INCH LCD MONITOR, KEYBOARD AND TOUCHPAD FORM FACTOR : 1U WITH LCD PANEL FOLDED CABLES : ALL REQUIRED CABLES FOR INTERFACING THE UNIT WITH 16 NODES
Please Note That if you Don't have same type of above mentioned Specifications, Kindly quote us; Equivalent for the same, it is acceptable to us.
NOTE : - KINDLY SEND CATALOGUE ALONG WITH THE OFFER.
AN EARLY QUOTATION WILL BE HIGHLY APPRECIATED.
Thanking You, Yours Faithfully, FOR PROFESSIONAL INDUSTRIAL ENGG. CO.
ANISH DESAI
