Conjugate heat transfer in porous
Old   June 21, 2008, 01:42
Default Conjugate heat transfer in porous
SAKTI
Dear all,
I read in the supplementary notes STAR CD version 4.02, we can conjugate heat transfer in porous media. And it is stated that we can create the solid material for it in the Thermophysical Models and Properties > Solids > Material Properties panel in STAR GUIde, but I cannot find this panel. Anyone have experiences in doing this case simulation please kindly share your knowledge.
Thanks
Old   June 21, 2008, 01:58
Default Re: Conjugate heat transfer in porous
SAKTI
One more additional question, for the detached solid cells block, is the size is same with the porous cells block or not?
Old   June 29, 2008, 18:29
Andrea
You must select first the Thermophysical Models and Properties > Thermal option panel. There you must turn on the conjugate heat transfer model, press apply and only then you'll be able to see the "solid" panel on the Star-Gui.
Hope that help
Regards,
Andrea
conjugate heat transfer Masood FLUENT 9 December 8, 2010 21:47
conjugate heat transfer ajay chandra FLUENT 3 October 26, 2010 17:14
conjugate heat transfer haiwind lee CFX 2 May 22, 2007 09:19
heat transfer in conjugate heat problems cirilo Siemens 1 April 18, 2006 09:16
Conjugate Heat Transfer in 3D Martin FLUENT 2 January 19, 2001 04:20
