June 21, 2008, 01:42 |
Conjugate heat transfer in porous
Dear all,
I read in the supplementary notes STAR CD version 4.02, we can conjugate heat transfer in porous media. And it is stated that we can create the solid material for it in the Thermophysical Models and Properties > Solids > Material Properties panel in STAR GUIde, but I cannot find this panel. Anyone have experiences in doing this case simulation please kindly share your knowledge. Thanks |
June 21, 2008, 01:58 |
Re: Conjugate heat transfer in porous
One more additional question, for the detached solid cells block, is the size is same with the porous cells block or not?
June 29, 2008, 18:29 |
You must select first the Thermophysical Models and Properties > Thermal option panel. There you must turn on the conjugate heat transfer model, press apply and only then you'll be able to see the "solid" panel on the Star-Gui.
Hope that help Regards, Andrea |
conjugate heat transfer | Masood | FLUENT | 9 | December 8, 2010 21:47 |
conjugate heat transfer | ajay chandra | FLUENT | 3 | October 26, 2010 17:14 |
conjugate heat transfer | haiwind lee | CFX | 2 | May 22, 2007 09:19 |
heat transfer in conjugate heat problems | cirilo | Siemens | 1 | April 18, 2006 09:16 |
Conjugate Heat Transfer in 3D | Martin | FLUENT | 2 | January 19, 2001 04:20 |
