Home > Forums > CD-adapco
system requirements
Old   June 24, 2008, 08:14
Default system requirements
Jaro
Dear,
I would need the system requirements for star-cd and some pre and post processors.
Thank You, Jaro
Old   June 24, 2008, 15:27
Default Re: system requirements
BastiL
This is strongly depending on the models you want to run and the environment you are working on.
Old   June 25, 2008, 03:11
Jaro
The model can have around 2 milions cells and it is planned to run on windows xp. 3GB RAM, CPU Quadro and 3Ghz, would be enough to finish the model in a acceptable time (1-2 hours)
Old   June 26, 2008, 04:33
usker
I would recommend that you increase your memory, because the number of cells depends on memory. I had similar experience before, my memory was also 3GB but I could not run cases with over million cells, although I used Linux.
Regards
Thread Tools
Trackbacks are On
mesh requirements! raja Main CFD Forum 2 August 14, 2007 13:43
CPU requirements aPpA FLUENT 2 June 19, 2005 00:24
System Requirements Christoph Gebhardt (Gebhardt) OpenFOAM Installation 1 February 3, 2005 08:30
memory requirements Novak Elliott CFX 3 June 6, 2003 02:50
CFD hardware requirements Jayprakash Main CFD Forum 1 February 1, 2000 19:24
