Intake manifold analysis
Old   June 30, 2008, 08:22
Default Intake manifold analysis
mehndan
I am going to simulate an engine intake manifold by star ccm+ .I have msss flow at inlet and pressure at outlet. Please answer to these questions:
1- These analysis should be compressible or incompressible?
I ran incompressible analysis , and as expected I found little pressure change. But I suspect that, this may be compressible analysis. Kindly guid me for this.
Old   June 30, 2008, 18:22
Default Re: Intake manifold analysis
Andrea
You REALLY need to do a compressible analysis!
In an intake system it's very important the dynamics of the fluid and the pressure-wave propagation phenomena, if you're interested in a transient analysis of the intake phase of the engine's cycle.
If instead you want to know the efflux coeff. of the intake duct, or something like that for example, also in this case the compressible fluid is very important: as you know the fluid will have a different behaviour inside the intake duct when that fluid is compressible, and you'll get also a different behaviour inside the boundary layer.
I suggest you do do a sim with compressible flow, try to use the solution of incompressible flow as initial condition for the new sim (so you lower the problem in the start up phase of the sim)
Regards,
Andrea
Old   July 1, 2008, 04:34
mehndan
Hi Andrea, Thanks a lot. I will run with comp flow and will update you if required.
Old   August 22, 2008, 04:24
ratan
hello sir, i am mtech student undrgoing industrial traning & would like to do project on hydraulic manifold analysis. i have got the idea of design of hydraulic ckt,as well as manifold.please guide me
Intake Manifold David Baker FLUENT 1 December 31, 2013 08:26
Flowing Intake Manifold Bill FloEFD, FloWorks & FloTHERM 2 November 18, 2008 04:10
Intake manifold analysis mehndan Main CFD Forum 6 July 3, 2008 05:28
Modeling of a airflow in a intake manifold Jack FLUENT 1 September 21, 2003 22:22
Modeling of a airflow in a intake manifold Jack Siemens 1 September 15, 2003 05:12
