Home > Forums > CD-adapco
why should we use velocity at inlet?
Old   July 1, 2008, 07:20
Default why should we use velocity at inlet?
rean
I wonder why we use velocity inlet boundaries to incompressible flows, but mass flow at inlet for compressible flows? Could anybody guide me???
Old   July 1, 2008, 16:41
Default Re: why should we use velocity at inlet?
Andrea
I guess that: for incompressible flow the information of pressure in each cell is known, because it can't vary with time due to the incompressible flow itself. So we specify only the velocity at the inflet of the model, because density is know from (p,T) and so is known the mass flux. That's not true in the case of compressible flow...there we need to specify the mass flux through the inlet boundary, to define the velocity of the fluid and the density entering the model
Old   August 26, 2008, 08:59
rean
Hi andrea, one other query. For comp flow, if we specify velocity also then also it can calculate mass flux. right? then why mass flux?
Thread Tools
Trackbacks are On
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
velocity inlet vs pressure inlet cheong FLUENT 6 April 9, 2011 03:07
velocity profile as an velocity inlet condition KEES Main CFD Forum 0 April 15, 2008 11:26
tangential velocity on a velocity inlet in 2D bretti FLUENT 0 July 3, 2007 08:42
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
