Home > Forums > CD-adapco
LES turbulence decaying in channel
Old   July 3, 2008, 17:11
Default LES turbulence decaying in channel
cfdIsMad
Hi
I am running a channel flow using LES. My problem is that turbulence after developing for a bit starts to decay in channel. And after a while I see zero turbulence in my domain. What can I do under such circumstances to sustain the turbulence. Thank you for your answer.
Old   July 4, 2008, 07:44
Default Re: LES turbulence decaying in channel
matej
Hi!
there are few things you can do here. But it all depends on your settings of the case.
try to be more specific on your boundary conditions and parameteres of the flow. with those information someone will surely help you. Few questions you should answer here:
1\ what is your inlet conditions? (in a channel flow, typially the outlet parameters are used as inlet, or some forcing must be used to keep the turbulence going)
2\ what is your mesh like? strucutred hexa? 2a\ is your mesh fine enough at the wall? 3\ what do you do at the wall? 4\ is your channel long enough? 5\ what is your Courant number? 6\ what discretisation are you using (space and time)?
answering those questions should make it clear where the problem is.
matej
Old   July 4, 2008, 08:40
cfdIsMad
Hi Matej
Thank you for your answer. I am using periodic boundary with pressure drop between inlet and outlet. I am using RANS solution as an initial guess. Mesh is hexa unstructured with very low YPlus values, below 1. Courant number is 0.6 and the length of channel is 1.6m. Discretisation scheme is central difference.
Thread Tools
Trackbacks are On
Turbulence in channel become laminar pankaj saha Main CFD Forum 1 November 9, 2010 07:16
LES turbulence decaying in channel flow cfdIsMad Main CFD Forum 6 August 21, 2009 12:17
LES turbulence decaying in channel cfdIsMad FLUENT 3 July 4, 2008 14:08
LES turbulence decaying in channel flow cfdIsMad CFX 4 July 4, 2008 06:29
Stabilizing turbulence equation in channel flow Biga Main CFD Forum 5 March 22, 2005 20:06
