Home > Forums > CD-adapco
PROBLEM: Scalar mass fraction
Old   July 14, 2008, 03:49
Default PROBLEM: Scalar mass fraction
Lorenzo
Dear all,
I've got a problem with some scalars in my model.
The numerical domain is represented by a slice of a cylindrical burner, in which I have imposed symmetry boundary condition, pressure condition both for the inlet and outlet. The model uses also the EBU combustion model. The model presents the following setup for the scalars: CH4 (Active, Transport), MIX_1 (Passive, Transport), O2 (Active, Transport), CO (Active, Transport), H2O (Active, Internal), N2 (Active, Internal), MIX_2 (Passive, Transport), CO2 (Active, Internal). N2 is also the background fluid. The Inlet boundary condition presents the following definition: CH4 (85%), N2 (15%) and MIX_1 (100%). The Outlet boundary condition presents the following definition: O2 (23.3%) and N2 (76.7%). The scalars initialization presents the following definition: O2 (23.3%) and N2 (76.7%). By running the simulation with the above setup I got good residual convergence, but if I do some post processing I point out that at the Inlet, the N2 mass fraction is not 0.15 (as imposed by the boundary condition) but is almost 0%.
Therefore I have tried to modify the scalar solution method by changing only the N2 solution method from Internal to Transport, such as: CH4 (Active, Transport), MIX_1 (Passive, Transport), O2 (Active, Transport), CO (Active, Transport), H2O (Active, Internal), N2 (Active, TRANSPORT), MIX_2 (Passive, Transport), CO2 (Active, Internal).By running the simulation with the above setup I always got good residual convergence, but if I do some post processing I point out that at the Inlet the N2 mass fraction is now right at 0.15, but the O2 mass fraction all the computational domain is not 0.233 (as imposed by the initialization) but is almost equal to zero.
Have you got any idea in order to solve this problem and have the right mass fraction for all the scalars?
Old   July 14, 2008, 03:50
Default Re: PROBLEM: Scalar mass fraction *NM*
Lorenzo
Thread Tools
Trackbacks are On
volume fraction,mass fraction,bulk mass flow nick CFX 0 April 25, 2008 09:51
How set volume fraction and species mass fraction Reginaldo Cotto FLUENT 0 August 31, 2006 04:58
volume fraction, Mass fraction and Bulk Mass flow Dr.jones CFX 1 January 25, 2006 05:32
mass fraction of scalar exceed 1 ema CD-adapco 0 August 8, 2005 22:24
How can the mass fraction of scalar in the 'SORENT BKOH CD-adapco 1 November 18, 2002 23:21
