CCM+ Surface Wrapper Export
Old   July 25, 2008, 11:12
Default CCM+ Surface Wrapper Export
Ross Kippenbrock
I am trying to use the surface wrapper to repair a piece of geometry and then export that as a standard file type (.stl, .igs, etc...). Is there any way that I can do this with CCM+ or do I need some sort of intermediate software to complete this export.
Any help would be much appreciated.
Thanks,
Ross Kippenbrock
Old   July 28, 2008, 15:50
Default Re: CCM+ Surface Wrapper Export
BastiL
IGS is geometry, but wrapper does does triangulated geometries. So to get IGS out of that geometry reconstruction is essential. No way to to with ccm+.
Export to triangular formats (like stl) may work with ccm+. However up to 2.08 only possilbe export was adapco database format. However this may have changed.
Regards.
Old   July 29, 2008, 14:27
ab
Ross,
Right click on Representations -> Wrapped Surface and go to "Export Surface"
Many formats are available including .stl. As BastiL said since the wrapper creates a discrete triangle mesh, .igs will not work.
Any way to export surface integrals into excel? Paul FLUENT 4 April 4, 2018 22:50
Tgrid wrapper surface Sam FLUENT 4 September 8, 2008 01:58
Surface Wrapper Zamir Rashid CFX 0 September 18, 2006 11:04
surface wrapper carno Siemens 2 February 10, 2005 04:34
Surface export Chris FLUENT 0 June 30, 2003 08:41
