Evaporation/Condensation in StarCCM?
Hi, I'm currently using starCCM+'s multiphase model to model a thin film of water flowing down a vertical flat plate (with an air/water interface), and have successfully achieved this.
The next step in my project is to add a heat flux through the plate and model the evaporation of the water into the air. Does anyone know if StarCCM is capable of this? I can't find anything in the help function about evaporation from heat transfer, only phase change due to cavitation. If anyone knows anything about this I would greatly appreciate the help! Cheers, Luke T |
If you are using Lagrangian Multiphase model together with evaporation model, then you can define/set your Boundary condition like either Escape/Rebound/Evaporate. Chose 'Evaporate' and set respective parameters.
I hope that it will help you. Cheers! |
