Heat Transfer in Multiphase Models (Star CCM+)
Old   August 5, 2008, 01:28
Default Heat Transfer in Multiphase Models (Star CCM+)
Luke Treadwell
Hi all,
Have been able to setup and run multiphase models without any problems (without heat transfer), however whenever I try to use the multi-phase heat transfer model for simple heat flux through a wall I get ridiculous results, with no apparent heat transfer through the wall.
Can anyone help please? Cheers,
Luke T
Old   September 7, 2008, 10:43
Default Re: Heat Transfer in Multiphase Models (Star CCM+)
mk_mat
Have you defined "Interface" between different components i.e. solid and fluid?!
Old   September 7, 2008, 20:14
Luke Treadwell
Yeah I had the interface defined between the phases, I eventually got some ok results for heat transfer from the wall into the water by setting the min allowable temp and max allowable temp to around about what I was expecting. I still couldn't get the heat transfer to happen between the water and the air, but this could be due to the fact that the version of CCM+ I was using was one of the first to have multi-phase with heat transfer, and so may not have had all the bugs sorted for multi-phase heat transfer.
I ended up going to a fluid-only model and using a slip wall as the interface (I'm now assuming that it is a laminar flow which doesn't change thickness). The evaporation will be found using the average temperature at the slip wall.
Thanks for your help!
Conjugate heat transfer models Alex Phoenics 8 April 6, 2009 15:58
Multiphase multicomponent masstransfer and heat transfer problem rajeevrkris OpenFOAM Running, Solving & CFD 0 February 6, 2008 03:21
Test Case for Multiphase heat transfer CFDtoy Main CFD Forum 0 April 20, 2007 12:29
low-re models and heat transfer coefficient Massimo Main CFD Forum 5 December 22, 2005 02:57
is there heat transfer option in multiphase model gayaz FLUENT 1 July 16, 2003 11:13
