polyhedral mesh with multiple processors
Old   August 20, 2008, 03:19
Default polyhedral mesh with multiple processors
user1
Hi All,
Here we have star-ccm+ with 4 license. and we also have shared memeory machines and parallel machines with 20 processors.
By default starccm+ uses only one license and runs in ONE processor. How can i make use of all the 4 processors? anybody knows how to set this in star-CCM+ or in proAMM?
I could not find the number of processors used to generate poly mesh.
it is very ugly, because we have a big complex geometry which needs to be meshed but we could not set the No. processors.
Can anyone help!
Old   August 20, 2008, 07:27
Default Re: polyhedral mesh with multiple processors
norbinou
first if you create a new simulation, you need to set the parallel options-> run all processes on local host->compute processes:4
Old   August 20, 2008, 08:17
user1
ok i will have a look. And do you know how this can be set in Proamm. i mean, Proam also supports poly meshing in mesh wizard, there we do not have such options. did you know anything for that?
Kind Regards,
Old   August 20, 2008, 08:19
Balduin Bankerotti
Not only when you first create it, but also when you open the simulation you can specify the number and location of the processors to be used.
Old   August 20, 2008, 10:32
user1
Can you please let me know where this option in Proamm.?
Old   August 21, 2008, 03:59
James
Although you can specify the number of processes for a simulation in Star-CCM+ the meshing itself is still carried out in serial, in pro-am the same is true, you only run the solver in parallel.
Old   August 21, 2008, 10:35
Pauli
Pro-Am mesh trimming runs in parallel. In the trim cell generation panel you specify the number of domains & the number of processors.
Old   August 22, 2008, 10:59
user1
The parallel trimmer is so ugly. i never recommend that.
So the ploy meshing becomes trivial when the domain is so large. so the serial only processor operation take quite long time for to compute mesh.
this is how it should n't be anyway.
Thanks guys.
Results from multiple processors Radhika Siemens 2 February 11, 2007 23:44
polyhedral mesh guang ai Siemens 3 May 28, 2006 01:02
Dual or multiple processors PC Li Yang Main CFD Forum 0 August 27, 2004 06:50
multiple processors calculation Noé Siemens 10 August 10, 2004 11:10
Fidap on multiple processors worth FLUENT 0 February 19, 2004 16:32
