Home > Forums > CD-adapco
which boundery should I use?
Old   August 26, 2008, 22:46
Default which boundery should I use?
elyor
I am analyzing the cavitation flow in the vane pump using star-cd V3.26. For the boundery I used:
1st case. Inlet for inlet & Pressure for outlet
2nd case. Pressure for inlet & Pressure for outlet
result is more accurate in the 1st case than 2nd case. But confusing thing is that when I specified 2bar for saturation pressure(abs) in cavitation panel using Rayleigh model in the 1st case, the pressure I got from result is 1bar in the suction region and interesting thing is that why fluid is not cavitatiing. Any idea why is that? I tried changing reference cell position, but still same.
I have following experimental results:
1.Pressure in inlet and outlet. 2.Flow rate 3.Velosity which I calculated using flow rate.
what boundery should I use? any suggestion is welcome!
Old   October 5, 2008, 01:14
Default Re: which boundery should I use?
ycwoon
Is that a rotating model? I also facing a problems of how to setting the boundary conditions.
Thread Tools
Trackbacks are On
kiva boundery condition ali Main CFD Forum 0 February 4, 2007 02:45
how to set the boundery condition ? Yun Heming Main CFD Forum 1 June 29, 2005 09:08
boundery conditions for Karman vortex street Rainer CD-adapco 6 November 6, 2003 08:06
