Home > Forums > CD-adapco
Multicomponent with Temperature dependent
Old   September 14, 2008, 21:59
Default Multicomponent with Temperature dependent
SAKTI
Dear All,
I want to simulate the real exhaust gas component, the case is temperature dependent. Which thermophysical properties should I use? The multicomponent option doest concern the temperature dependent right? how about the polynomial option? will it concern the multicomponent effect?
Best regards Sakti
Old   September 14, 2008, 23:48
Default Re: Multicomponent with Temperature dependent
usker
Multicomponent means concentration dependent, this option is suitable for multi-component mixtures. Depending on the density setting, STAR uses a constant specific heat Cv or Cp (or any other thermophysical property) for the background fluid. It also uses constant specific heats for any additional scalars present to calculate a mixture specific heat weighted according to the local concentration of each component.
Polynomial calculates the specific heat Cp (or any other thermophysical property) as a polynomial function of temperature (non-linear change of specific heat with temperature). If you click Define/Edit polynomial, it opens a special Polynomial Function Definition dialog in which polynomial coefficients may be created or edited, as necessary.
Regards
Old   September 15, 2008, 01:20
SAKTI
Dear Mr. Usker
Thank you for your reply, what if the properties value both concentration and temperature dependent?
regards Byan
Old   September 15, 2008, 22:09
usker
Then your Density will be a function of pressure and temperature.
Molecular Viscosity - MultiComponent, (if your Viscosity is temperature dependent, then you have to use Sutherland. Please, refer to Star-CD Methodology.
Specific Heat - Polynomial
Conductivity - Constant or Polynomial (usually Constant, but it depends on the flow conditions)
Thread Tools
Trackbacks are On
Temperature Dependent Loads RP FloEFD, FloWorks & FloTHERM 3 March 22, 2012 02:46
question about a temperature dependent HTC Christoph Ley Phoenics 2 June 5, 2008 09:05
Time Dependent Temperature Dependent BC Analysis RP Main CFD Forum 1 March 28, 2008 02:22
Temperature dependent property kdarc OpenFOAM Running, Solving & CFD 3 March 27, 2007 16:21
to take K & Cp as temperature dependent kishore rathore FLUENT 1 February 17, 2004 05:33
