September 1, 2008, 10:37 |
posdat user coding
Hi. I want to use a subroutine to print pressure and velocity at the end of the simulation at inlet veticies but don't know how to do that. Does anyone can help me? I have problems with the code.
September 16, 2008, 17:46 |
Re: posdat user coding
Hi Sara,
Try using 'call FsetBoun' macro in posdat.f, if using v4.06. You can get the inlet boundary faces and obtain pressure and velocity with those face id's. For more info, you can refer to Supplementary Notes. hirokata |
September 17, 2008, 16:02 |
thanks for your answer but I'm using v3.26 and I don't find FsetBoun. Thank you again.
September 18, 2008, 13:59 |
Across faces, you can use an internal boundary. After its creation, you can go to 'Monitor Boundary Behavior' and set up a monitor that will export your data per iteration.
Display Modes | |
VOF user coding | Ramki | Siemens | 2 | October 29, 2015 01:07 |
converting user-coding in V4 | Karl Mehler | Siemens | 0 | September 28, 2008 15:48 |
Print value to screen in user coding? | Cb | Siemens | 1 | September 30, 2005 07:29 |
plz, help me, CFD coding | sharuk | Main CFD Forum | 0 | April 6, 2005 05:09 |
User coding on NT w2k | Philip Jones | Siemens | 0 | November 26, 2001 03:43 |
