Boundary cell looping in posdat.f [v4.06]
Old   September 4, 2008, 20:24
Default Boundary cell looping in posdat.f [v4.06]
hirokata
Hello all-
I need to identify neighboring cell pair, front and back, at a (baffle) boundary, in order to calculate flux across it. I am using the FsetBoun looping macro in posdat.f to get the cells attached to the boundary as below:
C************************************************* **********
if (level.eq.1) then
do ir = 1, regi_no
if (regi(ir)%type.eq.BAFF) then
call FsetBoun(fs,0,ND_ALL,NSD_ALL,ir,ISIDE_ALL)
do nset=1,fs%no
do j=fs%ns(nset), fs%ne(nset)
i1 = lfc(1,j)
i2 = lfc(2,j)
! Baffle 1
if (ir.eq.7) then
! some actions
end if
end do
end do
end if
end do
end if
With the above code I can identify all the cells at the boundary. But what I really want to do is to identify the "pairing" cells across the boundary. I was hoping lfc(,) will accomplish this task, but it seems that, at a boundary, lfc(1,j) will return the neighboring cell number and lfc(2,j) will give me negative of the face number at the boundary. The version I am using is V4.06.
As I understand acquiring of pairing cells aross a boundary was possible in Version 3. I am hoping there is a simple way I can accomplish that that I'm not aware of. If any of you know a solution to this problem please let me know since I have been at this for months. Thank you very much in advance for your response.
hirokata
Old   September 5, 2008, 09:22
Default Re: Boundary cell looping in posdat.f [v4.06] *NM*
Stephanie
Old   September 5, 2008, 09:23
Stephanie
Are the cells on both side of the baffle belonging to different cell types. I would then use the function call cset and work with the subdomains.
Old   September 5, 2008, 11:21
hirokata
Hi Stephanie,
Yes, each side of the baffle belongs to a different cell types. However, what I'm trying to do is to identify the pairing cells during the iterations.
hirokata
Old   September 8, 2008, 02:55
Stephanie
well. I would find the pairs at the beginnning of the simulation, only once. I would save the pairs in table variables. If your pair cells belong to different types you can work with subdomains with call cset
Old   September 14, 2008, 12:42
hirokata
Thank you Stephanie. I used the call cset and was able to find the pairing cells. I checked the table feature but it only seems to be capable of handling simplest functions. Do you happen to know the way to access 'cell diffusion coefficient' while looping the cells in the domain? I found "af(j)" but I believe this is the face diffusion coefficient. I appreciate for sharing that info if you happen to know it. Thanks!
hirokata
Old   September 22, 2008, 14:34
Stephanie
sorry. I don't know how to get the cell diffusion coefficient. A call to Adapco support would certainly help. Or you should open a new forum message.
Looping over nodes of a cell (UDF) error Manoj FLUENT 2 December 1, 2005 00:30
Access cell coordinates and wall data in posdat.f Boban Siemens 5 July 22, 2005 04:25
How can I know a cell is boundary in the posdat.f wy Siemens 1 August 9, 2002 02:53
Looping over faces in a cell Senthil FLUENT 3 April 11, 2002 11:41
May I use global coordinate of cell centers in subroutine Posdat H. Shen Siemens 4 March 29, 2000 09:20
