File conversion from tape to hardisk
Old   September 24, 2008, 10:46
Default File conversion from tape to hardisk
Wei
I have an old .mdl file stored in a tape. The old .mdl file was recently being converted from tape to my hardisk.
When I read the file, error message printed is:
resume,C:/file1.mdl **WARNING - RESUMING FROM FILE CREATED ON VERSION 3.100 **ERROR WHILE READING RESUME FILE C:\file1.mdl
DATA MAY NOT BE COMPLETELY RESTORED
(MAY BE OK IF RESUMING FROM A FILE CREATED ON A LOWER VERSION) ************************************************** ********** *** *** pro-STAR Version 4.06.008 *** Build Date = JUN-30-2008 *** Copyright (C) 1988-2008 CD-adapco *** ************************************************** **********
Please give me some helps on this matter.
Thank you!
Old   September 25, 2008, 06:32
Default Re: File conversion from tape to hardisk
Anton Lyaskin
As it is said in the error message it "may be ok if resuming from a file created on a lower version", so first try to look at it - may be it was read. If not, than probably you have to look for older versions of Star-CD (3.2x or even 3.15 if it wouldn't help) and try reading the model with them.
Old   September 25, 2008, 07:46
Wei
Thank you Anton.
The mesh can be read after converting from tape to hardisk through binary code (previously I converted to ASCII).
However, the mesh is distorted and is not ready for simulation in this form. In addition, the coverted mesh can not be saved in current start-CD package v4. Do you have any idea what going wrong?
I agree that resuming through the lower version may be an effective way. But, I have difficultis to get an old version.
Old   September 26, 2008, 03:12
Anton Lyaskin
I think going through the older version is the only way. You can try to contact CD-Adapco, may be it's possible to send them the model and get it back in a new format
Old   September 28, 2008, 04:31
wrath of god
Hi
If your grid does not contain samm type cells then you could try saving it as an ansys, nastran or some other format and then read it into star 4. I've had to do this on a number of occasions and it's worked quite well.
allan
Old   September 29, 2008, 06:02
Wei
Thank you.
I exported the old .mdl file as nastran format and then reloaded successfully using star-CD 4.
PLOT3D file conversion Achilleas Main CFD Forum 4 February 2, 2011 20:32
[Other] Conversion file ideasToFoam georgette OpenFOAM Meshing & Mesh Conversion 0 August 8, 2006 20:18
PLOT3D file conversion Achilleas FLUENT 1 November 10, 2005 09:47
conversion of geo file from CFX-4 to fluent Min-Hua Wang FLUENT 2 January 26, 2000 17:01
Graphics File Conversion Christian Tollschein Main CFD Forum 3 May 5, 1999 03:02
