compressor problem.
Old   September 26, 2008, 06:42
Default compressor problem.
john
Hi friends,
I ran a case of centifugal compressor rotating at 1,00,000 rpm. I specified mass flow at inlet and pressure at outlet (2.5 bar). but I am really shocked wht i got. I got 2.7 bar inlet pressure (instead 1.012bar.) Was I wrong to put mass flow at inlet? Should I use pressure at inlet and pressure at outlet.But if I am using pressure bcs, how can I achieve mass flow rate??? pls clarify. thanks a lot.
Old   September 26, 2008, 09:52
Default Re: compressor problem.
Andrea
Hi
I don't know if you really need to use 2 pressure boundaries, but I know that you can specify a "target mass flow rate" at a pressure boundary...you can try to run your sim with this setup and specify in the target mass flow rate your desider mass flow.
Old   September 26, 2008, 10:02
john
hi andrea, thanks a lot for suggetion you are right. but by specifying "target mass flow", solver keeps mass flow but adjusts pressure according to that mass flow. is it right. while my pressure at outlet is fixed.
Old   September 27, 2008, 03:59
Anton Lyaskin
If you know the inlet pressure in advance, have you checked that this value and density and temperature you've specified at inlet are consistent with state equation?
Old   September 29, 2008, 05:15
Andrea
yes John you're right also, but as Anton said have you checked your equation of state? Because it sounds strange that you get an inlet pressure 1.5 bar higher than expected...with the desider mass flow rate and the exact outlet pressure. Have you checked the moving mesh? It's all ok with the fluid motion in the mesh also? (I suppose you use a moving mesh...)
Bye
Help needed Centrifugal compressor problem Raghavendra.M FLUENT 0 December 24, 2008 00:44
compressor problem. john Main CFD Forum 1 September 26, 2008 19:09
Another compressor problem Jack FLUENT 1 January 19, 2007 09:06
CFD Problem: volumetric compressor Gabriele Velenich Main CFD Forum 2 July 2, 2001 09:15
compressor problem joseph CFX 11 June 20, 2001 21:10
