EXTENDED DATA PANEL STARCD
Old   September 30, 2008, 13:59
Default EXTENDED DATA PANEL STARCD
Mary
Hi, I have a problem compiling user subrutines in the ufile directory. I think it must be done in extended data panel, but I am not sure. Between words BEGIN and END in this panel I should put the names of the subroutines?? or this extended data panel is only used for special STARCD modules like ERC? Thanks for your help!. Maria
Old   October 1, 2008, 11:52
Default Re: EXTENDED DATA PANEL STARCD
Andrea
Hi
User subroutines doesn't need to be named in the extended data section of the .prob file (here is written the extended data from the extended data panel). What kind of compiling problem you get? It's a problem about the compiler itself or a problem involving your user code (such as variables, ...). In short...what write down star when you try to run a sim?
Bye
Andrea
Old   October 1, 2008, 12:12
Mary
Hi, this is the error:
Inconsistency detected by ld.so: dl-fini.c: 195: _dl_fini: Assertion `ns != 0 || i == nloaded' failed!
It seems a compilation problem, but I donīt know if it is a STARCD problem or SUSE-linux problem. What do you think? Thanks! Maria
Old   October 7, 2008, 08:51
Andrea
Hi, it's sound strange, I really don't know what it is...sorry!
But I suggest you to look out for a Suse problem, because if it is a compilation problem then Star gives you information in the .run file about the line where it finds the problem...and if the compilator works correctly you should be able to launch star with the ufile dir and the standard subroutine without any changes to them. Try to launch a star sim without changing the subroutines...if it works maybe you have a Star Problem, if it doesn't maybe you have a problm with suse or the compilator...
Hope that help! Regards
Extended mode in Star-CD Kasper Skriver Siemens 4 January 18, 2007 02:35
Extended data Regis Siemens 0 July 22, 2006 15:31
CFD Survey extended. Free software. Don Main CFD Forum 1 January 20, 2006 14:04
extended outlet in cfx post Gab CFX 3 October 23, 2005 23:41
