Particle track data
Old   October 9, 2008, 09:00
Default Particle track data
Erik
I have solved a Lagrangian Multi-phase simulation. I don't understand the 'count' number displayed in the track data list. Does it have something to do with the following: when I calculate the volume of a droplet using the given diameter and using the volume for a sphere (4/3*pi*r^3), the volume is not the same compared to the volume using the given mass divided by the density of the liquid. Can someone explain this difference and the meaning of 'count'? I can't find it in the manuals. Thanks!
Old   October 9, 2008, 11:07
Default Re: Particle track data
James
Count is the number of drops of the given diameter that are needed to make up the total mass of that particular parcel. It is thus is a real number not an integer.
Count does not change along a drops track unless you have drop breakup on (and the conditions for drop breakup are met).
Old   October 13, 2008, 02:56
Erik
Ok, thanks for the information!
may i import flow field data to do particle track? Hao FLUENT 8 April 29, 2008 08:22
particle/droplet track data Jay Siemens 1 April 17, 2008 01:28
Particle Track Domenico FLUENT 2 February 19, 2007 18:56
Particle track James Bewley CFX 0 April 28, 2006 06:04
Particle Track Zahir FLUENT 16 March 31, 2002 00:29
