-   CD-adapco (http://www.cfd-online.com/Forums/cd-adapco/)
-   -   time dependent inlet subroutine. HELP!!! (http://www.cfd-online.com/Forums/cd-adapco/56858-time-dependent-inlet-subroutine-help.html)
jimmer November 5, 2008 14:23
Hello. I am simulating transient multiphase flow. My inlet is time dependent but I can't use a table. STAR 3.26 doesn't give u this option so I have to use a subroutine. Can anyone tell me what to put into bcdefi.f? The only thing I want is y-velocity (V) increasing at a certain rate with TIME. Your help will be much appreciated
Pauli November 5, 2008 15:08
Re: time dependent inlet subroutine. HELP!!!
Then enter: v = A * time where A is your rate constant. The remaining parameters will default to the values set in the NavCenter.
jimmer November 5, 2008 17:57
do I have to determine the global variable TIME in the bcdefi subroutine? I tried what u said but the subroutine didn't work. thanks!
Pauli November 5, 2008 18:57
No.
The bcdefi.f template should have the line:
INCLUDE 'usrdat.inc'
When you run the code, star will put usrdat.inc in your ufile directory. The variable time is provided by a common block within usrdat.inc. Time gives the current simulation time.
jimmer November 10, 2008 09:49
Thanks!!!
