ANSA mesh in star 4
I have a trouble with import of a mesh created with ANSA in STAR-CD v4. I get form ANSA no information about the boundaries becauese ANSA does not create *.bnd file. List->boundaries shows "0 boundaries". Without boundaries I cannot prescribe th b.c.
Who can give me a hint how I can create boundaries in STAR in a file imported from ANSA in the simplest way? I tryed it in GUI without success. |
Re: ANSA mesh in star 4
What I mean here, of course it is possible to define boundaries by clicking on faces or using "create by picking a zone" in prostar. It is very time consuming.
My question is how I can use geometrical information provided in the files imported from ANSA. I tryed to convert shells in prostar using CHSELL,ALL,1,ALL,1 BSHELL,0,1,ALL,1,0 but it does not work. No shells are converted into boundaries. Any idea here? |
I think you are looking for BFIND
Vset news edge Cdis on vert (to show the edge vertices) repl Bfin 1 vx (for boundary 1) This usually produces the boundaries you want pretty fast. Remembering that STAR covers uncovered faces in Region 0, you do not have to define all the walls typically. Note BFIND typically works better on quad surfaces, if you have tri surfaces some of the corners are missed as all three edge vertices are in the Vset. BCROSS usually sorts these out pretty fast. Also programming the function keys can speed things up when you have simple command sequences. |
i believe that you should try another mesh engine....... i believe that a mesh engine of a thirty party company always have problems .....
steven |
Re: ANSA mesh in star 4 *NM*
Many thanks on your comments. Principally I would mesh in STAR-CCM+ and solve back in in STAR v4 because the stakeholder of the project is wishing that we use STAR and has no preferences about meshing. I will try it if I have more time.
It should be really no problem to use ANSA for meshing as long as you know some prostar commands to define the boundaries.
If you have a shell with cell type 10 on a region you have to use the following commands to define the boundaries with region numer 1 (10-9): cset news type 10 vset news cset cset add vset all cset subs flui cshell 10 cset cset news type 10 bshell -9 cset |
